Full Fibre 150 (Eero) Wifi Disconnect
on 11-08-2023 07:50 PM
Message 5 of 5
Like the title says, I upgraded from Fibre to Full Fibre about a year and a half ago. The problem I've had since then is wifi speed, connection, and disconnects. The "Router" eero hub is located in the dining room; if you're in that room or close by, it's fine. If you're upstairs, the speed is down to 50 meg or less, and certain bedrooms just have no wifi, it keeps disconnecting and saying no wifi.
I know the Eero is designed to be used in a mesh, but TalkTalk only provided one, and I don't have the spare £100 for each new Eero mesh box. I've used wifi on the old TalkTalk WiFi Hub (Sagemcom) and had no problem, but this "new" device is just awful.
Is there anything TalkTalk can do about it? Do they provide more Eero to make a mesh, or do they expect you to do that? Can I request the Sagemcom router from them? I'm not sure if I sent my old one back when they installed the new one.
Thanks for any help. At this point, I'm thinking of switching to Vodaphone as it's cheaper and has a proper router.
Labels:
- Labels:
Connection
eero
Wifi
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
4 REPLIES 4
on 14-08-2023 06:47 AM
Message 1 of 5
I'm sorry to hear this. Have you been in contact directly with our Future Fibre Team as they may be able to offer some solutions for this?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 11-08-2023 09:34 PM
Message 2 of 5
It will still be functional. Just make sure that it has a WAN port which can connect to the LAN port on the fibre ONT.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 11-08-2023 08:55 PM
Message 3 of 5
Before I start searching attic for it (if it's even there) do you know if it will still work or would they of blocked or deactivated it? Not sure if TalkTalk does that.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 11-08-2023 08:46 PM
Message 4 of 5
The eero is indeed intended to act as part of a mesh system and if you want added units it is down to you to add them.
You could have a good look around to see if you still have your old router, if you do then try that and let us know how you get on.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Related Content
- Caller Display stopped working after upgrade from Fibre 65 VOIP to Fibre 150 VOIP in Home Phone
- Adding an extra Eero Pro 6 in Full Fibre
- Netgem Box - is it faulty? in TV
- Huawei-DG8041W router giving issues with Youtube and work as well as other internet options in Fibre
- Slow on ethernet in Full Fibre
