on 19-03-2023 11:24 AM
I’ve had Full Fibre 900 installed early February 2023, however, this morning there was a red LOS light on the ONT box (I think this must have happened from 1:50am this morning). I’ve done as much troubleshooting I can from my end ie. off/on, making sure all connections are secure, checking the fibre cable from the side of my home to the front of my home and have found no issues. I feel an engineer visit is the only remaining option…how do I go about arranging this considering Openreach provide the fibre to my home and not TalkTalk?
All help would be appreciated!
Kind regards,
Jason
on 24-03-2023 12:41 PM
on 24-03-2023 11:04 AM
Hi Jason
I'm so glad to hear that this has been fixed 🙂
on 24-03-2023 11:02 AM
Hi Debbie,
Yes all sorted and no LOS for now.
There appeared to be an issue with the initial engineer’s installation and condensation got into the splice connection into my home.
Kind regards,
Jason
on 24-03-2023 10:59 AM
Hi Debbie,
Yes all sorted and no more LOS for now!
There was an issue with the initial engineer’s installation and condensation got into the splice connection into my home.
Kind regards,
Jason
on 24-03-2023 09:26 AM
Hi Jason
Is everything working ok now following the engineer visit?
on 20-03-2023 09:12 AM
Hi Jason
Further information can be found here About your auto compensation credit
on 20-03-2023 09:10 AM
Yes I managed to get an engineer appointment using the “Chat Now” option.
With regards to not having internet from 01:50am on 19/03/2023 until the engineer appointment do you offer compensation?
Kind regards,
Jason
on 20-03-2023 09:08 AM
Hi Jason
Did you see my last post?
on 20-03-2023 09:05 AM
on 20-03-2023 08:54 AM
Hi Jason
I'm sorry for the delay.
I can see that this fault has been raised and an engineer visit has been arranged. Did you speak to our Faults Team?
on 19-03-2023 02:52 PM
Hi @J45ONV
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
