on 03-11-2023 02:41 PM
Hi just had installation today. Lights still flickering from orange to white. Speed test shows status poor.
Please help
on 04-11-2023 10:40 AM
@Gliwmaeden2 has pointed out to me that this is a continuation of another thread, which I was not aware of. I can help a lot with wireless reception issues if you want. I will leave it for now, unless you request my help on that thread, which I will subscribe to. Then I will be more than happy to try & improve your problems if WiFi based.
on 04-11-2023 09:07 AM
@silverbird63, staff will be back on Monday.
Perhaps better to continue on your previous thread to avoid confusion.
on 04-11-2023 09:06 AM
@KeithFrench, this is a continuation of this issue:
https://community.talktalk.co.uk/t5/Full-Fibre/Full-fibre-65/td-p/2988182/page/3
So staff are aware and in the midst of support, and there is a Complaint in progress.
on 04-11-2023 08:45 AM
We have full fibre. It's so poor I got 17 this am right next to the router .
Thank you
on 03-11-2023 09:49 PM
Are these speed tests done on a wireless connection? What speeds were you expecting (I have no idea what package you are supposed to be on)? If you have a PC or laptop with an Ethernet connection, try unplugging the cable out of the red WAN port on the router & connect it to the PC. What speeds do you get there?
on 03-11-2023 04:40 PM
We have a solid light now white, but speeds only download 45.5 and upload 19 it says status poor. Run into problem .
03-11-2023 04:19 PM - edited 03-11-2023 04:20 PM
That sounds like your installation is not completed correctly.
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
