Full fibre 65 and eero router compatible?
AstroNebulee
Message 6 of 6
I have just switched to the full fibre 65 data only package. I go have an eero router from my previous 150 package. Can I use this eero router instead as its much more user friendly, blocks ads and great on spam.
5 REPLIES 5
Message 1 of 6
Not a pain at all, glad you got it sorted.  🙂
AstroNebulee
Message 2 of 6
I think I've sorted it now. My huwaei p30 lite was on the 2.4ghz network instead of 5ghz. So I went into the eero settings-network settings and scrolled down to client steering and turned this off. Now my phone has connected via 5ghz and pulling better speeds wirelessly.
Sorry to be a pain. All sorted now.
Lee
Message 3 of 6
If it works, then great. 🙂
The wireless speed is another issue.
AstroNebulee
Message 4 of 6
I have tried it and speed seemed to be a touch lower wirelessly. Just wasn't sure if it was compatible with the full fibre 65 as talk talk don't send the eero 6 with any package lower than 150mb.
Lee
Message 5 of 6
I don't see why not, have you tried?
