The article you are trying to access is permanently deleted.
on 17-11-2023 02:36 AM
Hi. I have the full fibre 900 package. Was promised around 940Mbps.
however on all wireless devices, only ever get around 550.
what’s the point in advertising 940Mbps but only ever get 550 at best.
cheers
on 20-11-2023 07:17 AM
Can I just confirm, what speeds do you see if you connect wired at the ONT with the router removed?
on 17-11-2023 09:53 PM
On a practical and perhaps pragmatic note, what is it you possibly want to do on an iPhone that needs more than 500 Mbps?
17-11-2023 09:38 PM - edited 17-11-2023 09:42 PM
Hi, Your contract speed will only be guaranteed by TalkTalk via a wired connection since WiFi can be erratic at the best of times. Just moving several meters away from the router can result in huge speed drops similar to what you have listed. Also factoring in household objects, walls, ceilings and RF interference could further reduce speeds.
Unless your router is faulty the only real way to prove the incoming speed will be a wired test.
on 17-11-2023 06:09 PM
Hi. I have had the following
546
555
514
509
568
467
ive used Speedtest by ookla and also a few others. All with very similar results.
Many thanks
on 17-11-2023 04:06 PM
Line test is passing and speed test from the eero for the last month have all been over 900Mbps.
Do you regularly get speeds of 550Mbps, as though the speed is being capped at 550Mbps?
Which speed tester are your using? Have you tried more than one?
on 17-11-2023 01:34 PM
Done 👍
on 17-11-2023 01:20 PM
Thanks but could you also add your account number to the private notes section (community profile) and let me know when you've done this
on 17-11-2023 11:57 AM
Just done thanks
on 17-11-2023 11:37 AM
OK thanks. Can you please update your community profile to include your:
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
on 17-11-2023 10:23 AM
Hi. It is a iPhone 13 Pro Max and also a 14 pro max. The 13 has WiFi 6 802.11ax so should easily achieve my max available. The 14 should be the same if not better.
on 17-11-2023 09:12 AM
Hi Sasha1712,
Are the devices that you've tested with capable of wireless speeds higher than 550Mbps?
on 17-11-2023 08:29 AM
Hi. It’s at the 550 speed when I’m near the eero. The further I go away the slower it gets. Back of my house is approx 250-300. I’ve reset the eero. Tried multiple devices, but never get faster than 550 in WiFi. Don’t see why it would be advertised as 900 if I only get 550. According to the download speed within the eero app it’s says in average 950. But I’ve never ever seen anything above 550.
on 17-11-2023 06:47 AM
Good morning,
Can I just confirm, how far are your wireless devices from the eero? Does the speed improve if you move the devices any closer?
