Ghost no number messages
AliMT
Message 29 of 29
Since changing my line to full fibre I have been getting ghost messages every half hour day and night. The phone does not ring and displays a missed message with "no number". I have emailed, rung, had online chats and written letters, yet no solution. Virgin media customers have had the same problem, Anyone else on here had the same?
28 REPLIES 28
Message 1 of 29
That's great, thanks for letting me know 🙂
AliMT
Message 2 of 29
Thank you Chris. Fingers crossed not had any today.
Message 3 of 29
The ghost call issue should be resolved now, please let us know if you experience any further problems
Message 4 of 29
Message 5 of 29
Thank you
Message 6 of 29
I've ordered a replacement router, it should be with you within a couple of days.
Message 7 of 29
Lights not changed. My vpn tells me router password is weak. I know the router is the problem. Tv catchup works because I have no vpn on it.
Message 8 of 29
OK thanks. I'll pass the ghost calls issue back for further investigation. Your internet connection looks OK, have the lights changed on the ONT?
Message 9 of 29
No posted back. BTW ghost messages have started again. Laptop now no Internet. Am really getting frustrated by all this.
Message 10 of 29
Hi Ali,
Do you have any of the previous wifi hubs that you've been sent that you can test with before we send another replacement?
Message 11 of 29
Thank you.
Message 12 of 29
Message 13 of 29
That would be good. Preferably one in a sealed box that cannot have been tampered with. I have had routers delivered in open boxes before.
Message 14 of 29
Have reset router, yet again, will lyk if problems recur. Am not happy with the router, feel it is unsecured.
Message 15 of 29
OK, I can send a replacement router out to test with, would you like me to arrange this?
Message 16 of 29
Have done that multiple times. I am convinced the router at fault, vpn tells me TT website is unsafe and router has weak password. I want to go to adr but no deadlock letter.
Message 17 of 29
Thanks for confirming that the ghost call issue is resolved - Have you tried resetting your router to factory default settings? Restore your router to factory settings - TalkTalk Help & Support
Message 18 of 29
Hi Chris
Wow it's gone !!!!
Not my only problem though. Got  other problems still, Cannot connect printer or cctv camera, password and username not recognised. Installed a VPN which tells me my router password has weak password connection, I tried to change it but cannot. ( I have changed router password before) Been trying to get a deadlock letter from the chat agents, but no joy. I know problem would be solved if they would only send me a replacement router, but they will not do this. Wrote email to Priscilla M, would not send, then disappeared.
Suggestions?????
Thanks for getting rid of the ghosts.
AliMT
Message 19 of 29
Hi Ali,
This issue should hopefully now be resolved. Could you please let me know if you are still experiencing problems
Hugh88
Message 20 of 29
Cheers. Will do.
H
Anonymous User
