on 04-05-2024 10:02 AM
I have recently set up Groundstream DVA but not seeing caller identification. Phone was ok in the phone port of WiFi Hub
on 07-05-2024 09:28 AM
OK thanks, does everything else appear to be working OK, apart from Caller Display?
on 07-05-2024 09:24 AM
Hi Chris
Just upgraded to 150 VoiP and was sent an Eero 6. The Groundstream is attached to the Eero via an ethernet switch - but have tried it without the switch i.e directly in the back pf the Eero and still no caller ID.
on 07-05-2024 09:03 AM
Hi Boffee
Just to confirm, are you using the Grandstream DVA with an eero?
