I didn't get a starter pack so don't know my pin number
Petwen
Message 5 of 5
4 REPLIES 4
Message 1 of 5
The parental pin is something you can set yourself during setup, but unless you change this, the default pin is usually 1234 or 0000.
Message 2 of 5
Did the pinned post help you?
Petwen
Message 3 of 5
Yes TV hub
Message 4 of 5
Please see the pinned post here as I assume it's for your TV hub. If not please let us know the device you are referring to. Thank you.
https://community.talktalk.co.uk/t5/TV/PIN-Number-requests-using-TV-HUB/m-p/3034890#M186659
Anonymous User
