19-08-2025 09:15 PM - edited 19-08-2025 09:17 PM
I'm running the eero 6 provided, and I have been having none stop issues to my PC, running win 10. I use ethernet through powerline and a intel wifi card. Both have similiar issues.
The major issues I have is the problems are absolutely not consistant, and the solutions are neither. All of these fixes sometimes work, and sometimes don't:
I am also in the unique position that I spend half my time living in one location, and half my time in another. I actually transport my PC between these locations. I have no issues in the other location. Additionally the powerline set up used in the problem location worked perfectly before my swap to TalkTalk and the eero.
I can only conclude there is some issue in the eero, modem or with TalkTalk.
I've tried pretty much everything I can think of and I'm losing my mind. The system is essentially not fit for purpose. Is there another solution or fix I have not tried, or is it possible to request a different router and return the eero?
on 19-08-2025 11:15 PM
There's something between the interactions between the PC and the eero which is causing the issue. They're about 6/7m apart, through a few thick walls. I believe the powerline are on the same circuit yes. As I said, I used the powerlines on the same sockets in the past with a different router with no issues.
on 19-08-2025 09:51 PM
If it only affects one PC, I feel it is unlikely to be the eero. How far away is the PC from the eero?
When using the powerline adapters, are each of them on the same electrical circuit in your electricity consumer unit, where the fuses or circuit breakers are contained?
