Is a moderm required?
Debs*****
Sightseer
Message 3 of 3
Newbie here and not tech savy.i have just ordered my full fibre.TalkTalk to send me eero pro 6. Do I need to buy a modem? I think my old router must have one built in because I certainly have never had a modem before. If I need  modem then why
are they not sending me one??
Thanks for any advise
Message 1 of 3
Hi Debs*****
I can see that ferguson has given you the answer. You will receive an ONT (fitted) at install.
Message 2 of 3
If you have ordered FTTP then a fibre cable will be connected directly to your home, with what was is known as an ONT (Optical Network Terminal) installed inside. This effectively acts in place of a modem. And an eero, or other suitable router, will connect to that via an ethernet cable. All equipment will be supplied, as necessary.
