LOS Light fault - Light staying on
lewishagan
Message 10 of 10
Hi all,
I have an urgent case that I need looking into please: ref REP-13750710
Yesterday my internet went down and I need it back online urgently as I work from home. I suspect this is some kind of line fault and will need an engineer to come and check the line (I have tried all the various quick fixes and they don’t work so please don’t suggest those, thanks).
Urgent help would be appreciated, I will be available all day tomorrow (Wednesday 13th) for an engineer visit
It won’t let me put my picture in, but the openreach box is newly installed a couple of months ago, perfect condition internally and all cables attached as they should be, eero router is also immaculate)
best
Lewis
9 REPLIES 9
Message 1 of 10
lewishagan
Message 2 of 10
Thank you
i am at home all day today and tomorrow should an engineer be needed, just book in anytime and let me know or send a text confirmation
best
Message 3 of 10
Thanks for confirming. I'll pass this over to our Future Fibre team and ask them to take a look. I'll let you know when I receive an update or they contact you directly
lewishagan
Message 4 of 10
That would the one of the quick fixes always suggested by talk talk. Yes I have done that and still it does not work and the LOS light remains a solid red light
Message 5 of 10
I'm sorry, I can't see where it says specifically that you've switched the ONT off for 30 minutes. Could you confirm that you've switched the ONT off for at least 30 minutes and not just rebooted it
Message 6 of 10
As outlined in the initial post, I’ve already done that and all the possible quick fixes , still doesn’t work. The contrast red LOS light suggest it’s an outside line issue and will need an engineer
Message 7 of 10
Thanks. Can you switch the ONT off and leave it off for at least 30 minutes then switch back on. If you then still have no service please let us know
Message 8 of 10
Done
Chris-TalkTalk
Message 9 of 10
Hi Lewis,
Can you add your TalkTalk telephone number to your community profile. or your account number to the private notes section of your community profile, and we'll take a look at this for you
