6 hours ago
BT Openreach engineer installed FTP yesterday.
ONT is fine. Green lights and line check and all fine.
Eero 6 won't connect - see error message in subject of this message.
I have turned off ONT and Eero 6 for 30mins as suggested in other posts and reset Eero 6 as well.
It seems to be a common known issue and it requires talktalk at their end to do something?
Spent 2 hours on phone support for their algorithm to reach the 'turn off for 30mins' stage - which I'd already done before calling..
Talktalk WhatsApp support just disappear for hours at a time.
I'm at my wits end 🙂
Please help 🙏🏽
4 hours ago
Thank you. I've run a test on the line now which is clear. Can I just check, does the connection work if you connect a device wired to the ONT with the eero removed?
4 hours ago
Hi Michelle
I've updated profile thanks
I don't have an alternative contact number though - just my mobile
4 hours ago
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
5 hours ago
To save yourself time, please make sure that your community profile includes your first & last names, Full Fibre account number & if possible an alternative contact number. This can be done by clicking on your Avatar picture and then clicking on "My Settings" followed by:-
