New Hub2 fibre not as good wifi as Hub1 copper
Marvel
Whizz Kid
Message 27 of 27
Just had fibre 150 installed yesterday I now am using the wifi hub 2 vs SGK100206.
It seems that the wifi signal is not as strong as the old hub (copper )
The day before the fibre install i did a key room and also garden test where i mostly use the internet and am now comparing the results.
At first thought that the signal/ speed was slower but I think the signal seems to be coming and going which may account for my seeing poor results on the new compared to the old, depending on the exact moment I start the sped test.
I have a wifi app that is showing me that the router is using channel 11 but this channel seems to be varying star wise from full stars - all the way down to 0 star and yet other channels are consistently stable at full stars. See screen shot from phone.
wi fiwi fi
26 REPLIES 26
Message 21 of 27
The problem is that both routers use WiFi Optimisation, a feature that is supposed to ensure that you are always on the best channel. You can try changing the channel, but there is every chance that WiFi Optimisation will move you back again.
Marvel
Whizz Kid
Message 22 of 27
 I will get onto the info ASAP but is there a short cut, can I just tell the router to use one of the other channels that are not so flaky.
I think am aware of the best practices with regard to the best wifi signal re- position - facing direction, glass mirrors, vases and such like, so all of that is as best s it can be.. For reference the new router is in exactly the same position as the old one.
Message 23 of 27
Thanks keith I will get onto it.
Message 24 of 27
Hi @Marvel
@Michelle-TalkTalk has asked me to help you. That screenshot is not much use. I will need to see the main AP view, 2.4 & 5GHz channels plus the signal strength/time graphs. I will also need to know your network name as well. Please PM all of this to me to protect your privacy.
Message 25 of 27
@KeithFrench - would you be able to offer any advice on the wireless please?
Marvel
Whizz Kid
Message 26 of 27
As I understood it - I thought that the router changed its channel depending on it finding the best one but it seems to like channel 11 which looks iffy !
