on 14-06-2024 05:55 PM
I am currently connected on my iPad to the hot spot on my phone. My talktalk wifi will not connect to anything (weak security on iPhone 15 pro max iOS 17.4.1 or my iPad) and has also disconnected all my wildlife cameras, Alexa up and downstairs, etc etc. so many devices are not working. There is no wifi connecting even 3 metres from the router. The Ethernet connections are fine.
i have been told various things via chat - one stating that the talktalk t-link extender has an error although that cannot be the only problem. They promised a new extender on the 3rd June. If that is the problem then why have I not received it.
I spoke to various chat people yesterday for TW0 HOURS, only to be told eventually by one of them that talktalk has run out of extenders. What a waste of time and effort.
Please help as this is just not a good ‘full fibre’ service. What is going on?
I cannot live without a consistent fast broadband service, can somebody sort this out, please.
on 24-06-2024 04:16 PM
That does sound crazy @JennyR, what happens if you disconnect the Sky Qs from the TT router?
on 24-06-2024 04:13 PM
Thanks, Keith. I am currently using my phone hotspot although I worry about the data usage if I can’t use WiFi whilst at home!!!!
on 24-06-2024 03:57 PM
OK @JennyR that is fine. Please tell me what the engineer says if there is anything you can't answer, then I should be able to.
on 24-06-2024 03:54 PM
Hi Keith
i have limited wifi - so weird - some items are working - one Amazon echo works upstairs but the one one downstairs won’t connect. An’t connect iPad to wifi and phone occasionally connects.
I have arranged for Sky Engineer to sort it out but not until 10th July.
on 24-06-2024 02:52 PM
Hi @JennyR
First off, please can you PM me the Networks Around You screenshot from NetSpot, please make sure that you use the vertical scrollbar to ensure all of your networks are displayed. Then I can check if there are any Sky boxes still in there. Can you point me in the right direction to download Sky documentation that covers your boxes, then I will try & work out how the TV is supposed to connect. However, I would guess that the Qs have inputs from your dish and HDMI cables to the TVs. The main box I would guess then connects via Ethernet to the TT router. Then the TV connects to the TalkTalk network, via Ethernet or WiFi
on 24-06-2024 01:47 PM
What should the network settings in my main tv be showing? Should it be showing talktalk network or sky network? Should the main sky q voxvd connected to a sky hotspot forming its own network? I really don’t understand!!!
on 24-06-2024 01:41 PM
Hi Keith
i have reset the network connection to box (Ethernet) and reset the two mini q boxes to connect to the q box via wifi. Should that have put it right
on 24-06-2024 01:21 PM
Hi @JennyR
No rush at all, but I just wondered if you have had a chance to look at my last post yet?
on 23-06-2024 01:12 PM
Hi @JennyR
Yes, your last screenshot does tell me quite a bit. I think (not knowing anything much about Sky Q myself), is that at some time in the past you have connected the Qs to your Sagemcom via WiFi & WPS. I think you need to tell the Wifi side of your Sky boxes to forget this connection, which, as you said yourself you no longer use, as they connect via Ethernet now.
With the Qs originally connecting via WPS, then now know the Sagemcom's WiFi network name & password. They are advertising that network, as if they are part of your WiFi network, which they are not. There is now a connection problem, all of your devices can see the TALKTALK network name & connect to it, as they also know the password. However, the big issue here is that they could easily be connecting to the Sky Q boxes & not the TalkTalk router and then would either have a slower, or non-existent connection to the internet.
Please therefore can you default the WiFi configuration of the Sky boxes, so as they won't be part of your WiFi network?
on 22-06-2024 03:42 PM
Well, blow me down, all seems sorted now after my phone call to Sky. Apparently my recordings storage was 100% full and when this happens the main Q box does funny things and that is what has happened to my set up. I have just spent half an hours deleting recordings and in the delete box deleting everything permanently and all wifi seems to be back to normal.
i am now going to try to connect my cameras and sit outside with wifi back on my iPad. Thank you Keith, if you hadn’t pointed out the incorrect Sky set up I would never have found this out.
on 22-06-2024 03:00 PM
Have these Sky boxes ever been connected to your WiFi via WPS, as per some information that I have found out on the internet. If they are connected to the Sagemcom via Ethernet, how could they possibly know your TalkTalk Network name, that is surely only likely if wirelessly connected via WPS?
on 22-06-2024 02:45 PM
They are your Sky boxes, you tell me. They should not be using the same WiFi Network name surely as your TalkTalk router. What happens if you turn them off, how is the TalkTalk WiFi then?
on 22-06-2024 01:38 PM
I havn’t changed anything - the main Q box is connected to the router via Ethernet cable and the other 2 are wifi. Both are working. Who could have changed them?
on 22-06-2024 01:24 PM
Hi @JennyR
Sky Q boxes use a separate mesh system & do not work at all well when wirelessly connected to another router (TalkTalk or otherwise). They need to be connected via an Ethernet cable to the Sagemcom & should never use the same network name as the TalkTalk router. Can you at least set them to use a different WiFi network name & retry your TalkTalk wireless?
on 22-06-2024 01:17 PM
Hi Keith
i presume that those are my three Q boxes. One main box and two others
on 22-06-2024 01:13 PM
Hi @JennyR
Thank you that screenshot is fine (although I would have liked to have seen the others I requested). However, I can see one problem: why are 3 out of 4 routers using your network name SKY products? I would suggest that you turn all of those off & retest it.
on 22-06-2024 11:40 AM
Hi Keith
I now have a signal on my laptop. Save now sorted. I have sent you a PM can you reply so i will then have a reply optionl.
i have only one screenshot although can you let me know if i have to do a separate screen shot for each device in 2.4ghz (there are none showing in 5ghz although i know I do have a few devices in 5ghz.
on 21-06-2024 11:15 AM
Hi @JennyR
You just use the Save icon in the Snipping Tool:-
save icon
In Windows 11 they are automatically saved to the Pictures\Screenshots folder as well.
on 20-06-2024 08:08 PM
Hi keith
i have been trying to save the ‘snipping tool’ screen shots on my laptop. They are not automatically being saved or there is no option to save it. Any ideas.
also - tonight the wifi came back for about an hour - with quite a strong signal!!
on 16-06-2024 10:41 PM
Hi @JennyR
Please, PM the screenshots to me, to protect your privacy, do not put them in your thread, as anyone can see them. Hence why I have removed it from your post.
Please make sure that NetSpot is maximised before taking any screenshots & use the Insert Photos with the Size parameter set to large.
Please read the instructions again in my guide on how to use Netspot. You have not set the Select All option, so only your networks will be shown. Please also get all of the other screenshots that I have requested.
