Own router and phone
Lnicklin
Message 5 of 5
Has anyone got their phone working with their own router?
is there an an analogue to digital converter?
or is there any settings I can try with a SPA device or similar?
4 REPLIES 4
Message 1 of 5
Hi it is a Cisco router.
Message 2 of 5
OK, have you reached out to the router maker to ask how to make this work for you? A DVA should do the job, but I couldn't speak for any configuration required. What make/model is it by the way?
Message 3 of 5
Hi I do have one of them routers with the built in port however I’m using my own router.
Message 4 of 5
Do you have Full Fibre with VoIP from TalkTalk? If so, you should have been supplied with a Hub which includes a built-in digital voice port, or an eero along with a separate DVA. Otherwise, please clarify.
