Problem Connecting to Fortinet VPN
DarrenW66
Message 39 of 39
Hi there, I've recently started experiencing connecting through Fortinet VPN from my home network (Talk Talk Fibre 65) when connecting through mobile data doesn't seem to have this problem.  is this a know problem from Talk Talk wifi and if so, are there any known solutions, please?
38 REPLIES 38
Message 21 of 39
Hi Keith, thanks for this update, it may have fixed things:)  I'll check over the next couple of days, though as sometimes I have been able to connect through the vpn and then the problem has arisen again.   If it is fixed, I'll action the 'Accept' as requested.
If it's not fixed it, I'll repost the post that was deleted (as far as I can remember  what I wrote).  Sorry I didn't get to this before now, I've been tied up with some other things over the last couple of days.
Best regards
Message 22 of 39
Hi @DarrenW66
Apparently, there was a bug in Windows 10/11 that has been affecting VPNs recently (mine were unaffected). This has been fixed in the Patch Tuesday update for Windows released today. Although this is normally a security only update, Microsoft has also rolled out this fix as well. Once updated, please can you retry? I am not hoping for much, but you never know.
Message 23 of 39
Hi DarrenW66,
Your last post has been automatically moved to spam quarantine. Could you try posting it again without the link, hopefully this will go through OK
Message 24 of 39
Hi @DarrenW66
Which VPNBook SSL servers were you using, I haven't found any supporting SSL. What I did do was to analyse a connection attempt of my own that gets to about 48% using a VPNGate SSL server in Wireshark. The Forticlient contacts the server and performs some encrypted exchange. Are you sure that you don't need to use any certificates? Did this ever work to your employer's VPN server?
Message 25 of 39
Hi again Keith, thank you for persevering with this.
Generally it gets to 40% before failing.
Interestingly, if I run the open vpn (vpnbook) on my machine and then connect to Fortinet, it seems to connect much better.
I don't know if that helps explain the problem here?
Thank you again,
Message 26 of 39
Hi @DarrenW66
I have been trying all of the free SSL VPN servers that I can find & can't connect to any of them. When you try & connect to your work network, what percentage does the connection reach before it fails?
Message 27 of 39
Hi @DarrenW66
Thanks for that, I'll give it a try & come back to you.
Message 28 of 39
Thanks Keith, just sent to you....
Message 29 of 39
 @DarrenW66
Please can you send me a PM (to protect your Privacy) with a screenshot of how you have it configured, so as I can test this in the same way that you are using it?
Message 30 of 39
Thanks, I'll have a look at it.
Message 31 of 39
Message 32 of 39
Hi @DarrenW66
I have tested that router for any free VPNs that I could find at the time, but did not know that there was a free version of that one. I think that you forgot the link.
Message 33 of 39
My apologies Keith.  It is SAGECOM FAST 5364-3.T8
Here's the link to the Forticlient download page.  I'm using the free version headed 'Forticlient VPN' at the bottom of the download options, Windows version.
Thank you again, so much, for any help you can offer.
Message 34 of 39
Hi @DarrenW66
The TalkTalk WiFi hub is not much use I am afraid description e pull up plastic panel, there is a sticker behind that which will tell you. It is probably one of these:-
  • Sagemcom FAST 5364
  • Sagemcom FAST 5464
  • Huawei DG8041W
Do you have a link you could give me to the VPN client's support site, as those protocols are ones that applications use, rather then the one that the VPN client uses to connect to its server.
Message 35 of 39
Thanks Chris.  Updated as requested.
Message 36 of 39
Hi Keith, thank you for trying to help me with this.
I'm using the TalkTalk wifi hub.  And I think this Fortinet vpn is using either TLS1.3 or SMBv2.  I looked those up on their website as i don't know how to find this information out otherwise.  Sorry.  Grateful for any help you can give me, though.  Thank you
Chris-TalkTalk
Message 37 of 39
Hi DarrenW66,
In addition to answering Keith's questions can you please update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
Message 38 of 39
Which make/model of router do you have?
Do you know which VPN protocol this VPN client uses:-
  1. PPTP
  2. L2TP-IPSec
  3. SSTP
  4. IKeV2
