This post is a little old and may not be relevant anymore…
Old post notification
Repeated problem with Eeros and Fibre 900
DHA_UK
Message 20 of 20
I have had Fibre 900 since April this year. Generally I am very happy with the service.
However I have had a recurring issue, which used to happen every 3-4 weeks and now occurs every 2-3 days.
My internet speed will drop to 94mbps up and down. The line speed when connected directly to my computer shows full speeds as expected but via the Eero it sits at 94 and 94.
Previously talk talk have said restart the routers, then speak to Eero. I have now spoken to Eero and they say, restart the routers and speak to your internet provider.
So essentially its restart the router every few days............
Not really support from anyone when there is clearly an issue with either my line or my talk talk supplied routers. And yes, they are up to date with the latest software.
19 REPLIES 19
Anonymous User
Message 1 of 20
Hi Ryano1,
Please can you create your own topic and we'd be happy to take a look at this for you.
Message 2 of 20
Yep between ont and router
Message 3 of 20
Thanks for letting me know. So you replaced the Ethernet between the ont and the eero with a different one to the one that was supplied? I’ll give that a try and hope it makes a difference.
Message 4 of 20
@Ryano1, you've posted on another customer's old thread.
Start a thread of your own, and that will enter the queue for attention from staff.
You need to return to the message board and click start a topic.
Also complete your community forum profile details. That is so that staff can identify your account. Go via your avatar; settings; drop down menu....Personal Information. SAVE CHANGES once you have added your account number.
Message 5 of 20
Hi there
I eventually resolved the issue by replacing the Ethernet cables that were supplied with the routers and have had no speed problems since i did this. Hope this helps
Message 6 of 20
I’m experiencing a nearly identical issue to the one described in this post. I’m finding that almost daily my speed is dropping to 94mb download and 94mb upload. This shows when running a speed test in the eero app. I’m on the 900mb plan. Only way to resolve is to reboot the gateway eero, which brings the speed back to normal.
This really frustrating. Line tests etc show no issue. Support isn’t hugely helpful.
Message 7 of 20
Yes, I think it definitely worth a try
DHA_UK
Message 8 of 20
Not yet, but that was a consideration. I would need to re-create the network to do that reading how they are configured. I will probably try that the next time the speed drops off
Message 9 of 20
OK thanks, have you tried swapping the eero's round so that the gateway is the leaf and the leaf is the gateway?
DHA_UK
Message 10 of 20
Eero haven't given any indication what it might be, their latest advice (outside of contacting my ISP) is as follows;
Since you have already tried the troubleshooting steps and still the speed is dropping, kindly try this troubleshooting. When you internet drops:
  • unplug the main eero from your modem and connect a computer directly to your modem of your internet provider as it still shows here that your speed is good in our system.
  • Kindly try that connection a computer directly to computer to confirm if there are no packet loss from your internet provider.
If this you can try this step 2-3 times and still the same, kindly swap the eero. If nothing works after doing all of these, please update me. Thank you for your time and patience.
Message 11 of 20
Thanks, did the eero support team give any indication what the problem might be, it's hard to see that it's a problem with the internet connection if the speed is fine when connected directly to the ONT?
Message 12 of 20
That is correct yes, whenever the Eero speed drops off the ethernet cable to the ONT connected to my computer has full speeds.
Message 13 of 20
And when the speed drops if you connect the ethernet cable from the ONT directly to your computer the speed is back to 900Mbps?
DHA_UK
Message 14 of 20
Right now it is as expected 940 down 111 up
Message 15 of 20
OK thanks, what's the speed like at the moment?
DHA_UK
Message 16 of 20
I had to restart the eero yesterday morning at around 8.30am
Message 17 of 20
Hi DHA_UK,
How has it been over the last 24 hours?
DHA_UK
Message 18 of 20
Thanks for the offer. However the speed issue on the eero says wired speed test, so i am not sure if looking at WiFi interference will solve the problem completely.
Message 19 of 20
The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
Whilst the Eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use. It is possible that you may also need to purchase additional Eero nodes as it is supposed to operate as part of a mesh system. I can help with any of this. However, I would suggest that you follow my help to find out what the root cause of the problem is, before throwing money at it.
Anonymous User
