eero 6
walker1
Message 12 of 12
Received a new eero 6 router today on fiber 150 package and cannot get it to connect , always fails with it not getting a wan address , the old wifi router conects perfectly to talk but not the new eero 6.
any advice apprecited
11 REPLIES 11
Message 1 of 12
That's great news, thanks for letting me know 🙂
Message 2 of 12
Good evening Chris
The change worked . I can now connect the eero no problems . Thanks for the help
Message 3 of 12
Message 4 of 12
Thank you , I will test this evening and report back the outcome .
Message 5 of 12
OK, I've made the change, it should still work with the Sagemcom but should also now work with the eero
Message 6 of 12
OK, I'll make the change now 🙂
Message 7 of 12
Yes that’s fine  I am out all day until 6pm so don’t need internet till then
thanks for the help
Message 8 of 12
Hi walker1,
I think I know what the issue is. I can make a change now that should fix the issue but it may disconnect you from the internet. Is it OK to do this now?
Message 9 of 12
There does seem to be a number of these, only TalkTalk can get it resolved.
walker1
Message 10 of 12
Eero can't connect to external IP address - TalkTalk Help & Support
Seems to be exactly the same as my problem
Message 11 of 12
Anonymous User
