Router needs reboot
hutchys
Message 14 of 14
Have a TalkTalk WiFi Hub router (reddish face to it). Finding that have to reboot it most days as various devices seem to lose connection... but not all things. The printer drops out, all the smart devices like plugs and bulbs, android phone.... other devices like ipads/iphones all seem fine. Has not always been like this.... rebooting the devices themselves never seems to work, only if we hard boot the router.
Guess we have had it 6 years of so and trouble in last 6 months
13 REPLIES 13
Message 1 of 14
Hi @hutchys
@Michelle-TalkTalk has asked me to help you. Please can you send me a PM with all available screenshots from this WiFi Explorer when the 2.4GHz band disappeares and I will investigate it for you.
Message 2 of 14
@KeithFrench Would you be able to offer any additional wireless advice please?
Message 3 of 14
Wife had to reboot today. Can tell if the 2.4GHz had "vanished" again from the WiFi explorer as I was not at home, but I suspect yes.
Interestingly though the router did seem to reset itself back to channel 1. Have set it again now to ch 11 to see if that is any different.
Is it "usual" to have the 2.4G band vanish .. The SSID just does not appear on any 2.4G only devices or the WiFi scanner, but the 5G is fine.
Is there anything I can look at in maintenance logs of anything like that to help understand ?
Cheers
Steve H
Message 4 of 14
How has your connection been over the last 48hrs?
Message 5 of 14
For a play I have moved to ch 6 on the 2.4G as everyone around seemed to be on ch 1.
see if that helps
Message 6 of 14
Thanks for that.
I didn't try any sort of soak test 🙂
So I did notice this morning that initially all was working (prime candidates for not working are smart lights, printer, some phones).
Late morning some stopped. So it was ok for 16 hours or so.
While not working I logged onto router admin and dumped off screen what of devices connected.
Used a WiFi scanner to see what was around me... sort of suspecting something like that with the new router in place.
Rebooted router and recollected devices and WiFi scan info.
Initial feeling is that my 2.4GHz band had vanished - this ties up with the the devices that vanish.
It obviously comes back after a reboot and all connect again.
Anyone know what can make the 2.4G band vanish, or any tricks to stop it ?
Thanks in advance
Message 7 of 14
I think they generally allow 14 days for return, but I wouldn't recommend a soak test, just use the new router as you normally would.
Message 8 of 14
Received the new one ok and up and running, thanks again. It said to return the old one or be charged £50. Assume it's ok to wait a week while the new one gets a soak test ?
Steve H
Message 9 of 14
Hi @hutchys
No problem 🙂
Message 10 of 14
Hi Debbie,
That sounds great. Thanks you very much for responding quickly.
SH
Message 11 of 14
Morning @hutchys
The line tests are clear - No faults detected. I have ordered you a replacement router, please allow 24-48hrs for this to arrive.
hutchys
Message 12 of 14
Great, thanks Ferguson
Message 13 of 14
If you would like the support team to look into this for you make sure that your personal details including TalkTalk phone number or account number are complete on your community profile (click here) so that they can link your forum identity with your account and then wait for them to respond. It won't be until Monday at the earliest.
