SagemCom Fast 266 WiFi Booster
dobbor11
Message 15 of 15
Hi, I have just ordered the SagemCom Fast 266 WiFi Booster for my Hub 3 900mb service and would like something clarifying please.
Will the booster be connected via ethernet to my Hub 3 and act as wired backhaul?  In that the Wifi signal will be as strong at the booster as the Wifi Signal at the Hub 3?
Or does the Hub 3 just bounce the Wifi signal to it?  Hope this makes sense.
Jeff
14 REPLIES 14
Message 1 of 15
Thank you for the support @KeithFrench
Message 2 of 15
And you relied on that? It was not TalkTalk information then?
Message 3 of 15
It was an AI generated reply on google and someone posted it on Reddit. That’s why I was double checking.
Message 4 of 15
Whilst I have no control over TalkTalk's documentation, where did you see that, as the 266 has always been Wi-Fi 6? It is just when used with a Wi-Fi Hub 1 or 2 that the router remains WiFi 5, whilst devices can connect to the 266 at Wi-Fi 6.
Message 5 of 15
Thanks for clarifying Keith, info on the internet is incorrect then. I just like to know what I’m buying and interested in the technical side of things. Every days a learning day as they say.
Message 6 of 15
Thank @KeithFrench, appreciate your help always.
Message 7 of 15
Hi @dobbor11
You are wrong, the 266 is WiFi 6, so combined with the Hub 3, this gives you a Wi-Fi 6 mesh. What else do you want to know?
dobbor11
Message 8 of 15
Keith, I have been trying to find some info on this booster, am I right in saying it's only Wifi 5 and not Wifi 6?  Is this going to cause an issue?  Jeff
@KeithFrench
Message 9 of 15
Hi @KeithFrench thank you for the support, please mention me if there is a need for anything account specific.
Phili
Message 10 of 15
That is correct. This is because the Sagemcom mesh uses a "Shared Wireless Backhaul". This is the case with nearly all domestic mesh networks, including most of the eero range. By using an Ethernet backhaul, this becomes a dedicated backhaul, making a big potential improvement in speed. (all depends on where the slowest part of the connection to the internet is, which is normally the fibre network). In most cases, however, this is not a problem.
Some of the very expensive mesh networks that can be bought, do have a dedicated radio that is not available for the user, obviously giving them a dedicated wireless backhaul. They might be costing upwards of £500 and how much does a long Ethernet (Cat 6 minimum) cable cost?
Message 11 of 15
Many thanks for your reply Keith, you clearly have a depth of knowledge in this area. So basically, I am right in saying that the advantage of having a booster connected to the Hub 3 via Ethernet will provides a direct, full-speed connection from the router, ensuring maximum bandwidth reaches the booster? And not just receiving a weaker WiFi signal possibly halving it?
thansk
Message 12 of 15
Hi @dobbor11
They will act as a mesh network, irrespective of the backhaul medium. Will the WiFi signals be the same strength - that is all down to the mesh algorithm that it uses. Most of the time, both nodes in the mesh network will use the same Wi-Fi channels on each band.
If you just had a router & extender, not in a mesh, they give out a fixed signal strength. Therefore, at certain locations in your property, there is every chance that the two WiFi signals (for example, on channel 6 in the 2.4GHz band), unless operating on different Wi-Fi channels, will interfere with each other. This is likely to reduce the speed/throughput at that point, effectively creating a new blind spot.
All nodes in a mesh network work to avoid such problems. It is important to understand that the Wi-Fi signal from the router is most likely transmitting at a higher level than a device does back to the router. If the device's output signal is lower, this can cause problems with Wi-Fi performance. The device may be able to receive a signal from the router, OK. However, it may not be able to connect to the router's Wi-Fi, as its transmit power is too low. If it does connect, it may slow down all other devices. This is because the device that is too far away is consuming a lot of airtime trying to connect or respond to the router. Therefore, it is not just the location of the router, but also that of the device that needs to be considered.
Message 13 of 15
Keith, they will be connected together via Ethernet. So I assume they will act as a small mesh system and the WiFi signals from both the Hub and the 266 will be the same strength ? Jeff
Message 14 of 15
The 266 will use a wireless backhaul unless you connect the two via an Ethernet cable.
