04-12-2025 05:01 PM - edited 04-12-2025 05:03 PM
I have received an email from TalkTalk saying that Callsafe will shortly be chargeable. As far as I am aware, as I am using VOIP (digital voice) and call safe is not avaiable, I am assuming this is an error and no additional charge will be made to my account.
on 08-12-2025 09:18 AM
Hi @Weevie if you have any query regarding your account, kindly start your own thread and we will be able to assist you.
on 08-12-2025 09:13 AM
We can use this to "leave without penalty" if anyone is planning on leaving anyway....
They apparently are offering this option in any case it's possibly a good move prior to the takeover of TT ISP business by Utility Warehouse !!
on 08-12-2025 07:15 AM
@aa2000 To get help, you must start your own thread. To create your own thread, go to the main page for the board in question & click the "Start a topic" button.
06-12-2025 10:13 AM - edited 08-12-2025 05:25 AM
Yes its very confusing, I have a banner on my account saying that I will shortly be charged £1.00 per month, I don't mind that its a great system, also there is a highlighted link with a shortcut to callsafe on the banner, If I click on it it tells me its not available with VoIp. however it is and seems to be working !
Just waiting for a response from TalkTalk now my Questions have been highlighted and escalated.
Perhaps it would be an idea to start your own thread that way Talktalk will know its a general issue. I am sure many wont bother and just pay £1.00 a month, without checking if it works or not.
On the web site it did say it wasn't available with digital voice awhile ago, checking now it says available to all. I am hoping its just an error with 'My Account' and will be sorted. I would like to be able to be able to edit blocked and allowed numbers via 'my account as before'
06-12-2025 08:42 AM - edited 06-12-2025 08:47 AM
I'm also a TT VOIP customer and interestingly, whereas CallSafe was effectively removed from My Account and from 1472 for many months, all of a sudden I discover that the service has been restored on 1472, though not in My Account.
So confusing then that we are informed by TT that 'CallSafe isn't available with Digital Voice'. If it worked with VOIP originally, why are TT saying not now, yet at the same time reinstating it on 1472 at least? I too want to keep it as it's a great service that does what it says on the tin.
on 05-12-2025 09:26 PM
Sure it will be sorted soon ! It's well worth £1 a month before the days of callsafe we were getting about 5 or 6 nuisance calls a day with callsafe its zero.
on 05-12-2025 09:21 PM
Yes, it is undoubtedly confusing! And annoyingly My Account does not always behave as it should. But it seems that you do have it and the options are as advised.
on 05-12-2025 09:17 PM
@ferguson Yes that's fine I am Ok with that the problem is that according to my account its not compatible with Voip therefore its not available under manage settings. The Web site now says callsafe is available to all, clearly a change of policy by Talktalk.... my questions have been flagged and escalated .. perhaps have a definitive answer soon
on 05-12-2025 09:07 PM
OK, in which case you are going to be charged £1 a month from January, or you can cancel beforehand if you do not wish to continue.
05-12-2025 08:32 PM - edited 05-12-2025 08:38 PM
Yes, as far as I can tell, we certainly have had no nuisance calls, calls are being screened too
regards
on 05-12-2025 08:17 PM
Is it working on incoming calls?
on 05-12-2025 03:21 PM
Yes @davidl1 and I have escalated this for you and I will be able to give you an update on this thread as soon as I get a respond.
on 05-12-2025 03:20 PM
That doesnt seem to be the case, its a bit confusing ! I have asked similar on this post, just awaiting clarification. I have upgraded to voip and still have callsafe ! But it dowsnt show on my account dashboard
05-12-2025 03:07 PM - edited 05-12-2025 03:09 PM
Thanks @Gliwmaeden2
on 05-12-2025 03:06 PM
@Weevie, just set up Last Caller Barring instead.
Information about it is found using the forum search engine.
05-12-2025 02:08 PM - edited 05-12-2025 02:09 PM
Hi @Weevie To get help, you must start your own thread. To create your own thread, go to the main page for the board in question & click the "Start a topic" button.
on 05-12-2025 02:06 PM
I understand that Callsafe is not available on Full Fibre (VOIP) - Is there another way to block unwanted callers ?
because before Callsafe, we used to get many spam calls and I will not be very happy if they resume, if I upgrade to FTTP
on 05-12-2025 10:12 AM
You welcome @davidl1.
on 05-12-2025 10:10 AM
on 05-12-2025 10:08 AM
I have escalated the issue to my manager too and once we have an update, we will be able to respond here on the thread.
