on 10-01-2024 03:40 PM
I keep getting this message when I try to activate my EERO router. I connected all the cables correctly and created an account. I get to the stage where I name my WiFi and created a password while the EERO is blinking blue, then it doesn't find it and gives me this message. Both devices are connected to power but it just doesn't seem to work. Help please.
on 11-01-2024 03:32 PM
No problem Violet, have a nice day
on 11-01-2024 03:28 PM
That's great. Thanks alot Chris.
Have a nice day.
Violet
on 11-01-2024 03:25 PM
OK thanks. I've passed this to our Future Fibre team. I'll let you know when I receive an update or they may contact you directly
on 11-01-2024 01:44 PM
Yes that's correct- they're still on and the EERO is also still blinking blue
on 11-01-2024 01:36 PM
Thanks for trying that. And the Power and Ethernet lights are still the only two lights on, on the ONT?
on 11-01-2024 01:34 PM
Thanks for your time Chris really appreciate it.
I have tried that but I'm still getting the same error message. It doesn't find a Gateway when it searches using a Bluetooth connection so I scan the serial number instead and then choose the room in which my router is and name my WiFi and set a password. After I do all of that I get that same message I have uploaded yesterday.
on 11-01-2024 11:39 AM
Thanks Violet. Could you switch the ONT off and leave it off for at least 30 minutes, then switch back on and check to see if you then have an Internet connection
on 11-01-2024 11:37 AM
The Power and Ethernet lights are on and thr EERO is blinking blue.
Violet
on 11-01-2024 11:30 AM
OK thanks. Could you tell me which lights are on, on the ONT
on 11-01-2024 10:02 AM
Hi Chris, yes still the same
on 11-01-2024 09:03 AM
Hi MissVee,
How are you getting on, are you still experiencing this problem?
