on 04-12-2025 10:05 AM
My Fibre 150 VOIP connection is due to renew soon, but am looking to upgrade to Fibre 500 VOIP.
I have some questions below that hopefully one of you can answer.
I currently have Eero 6 running in Bridge Mode / Legacy Mode linked to a TP Link router (wifi off) to provide ethernet ports to link Cat 6 cable to office and cable to Digital Voice Adapter.
Q1 : Am I likely to be supplied with the latest WiFi Hub 3 with green phone socket when I renew/upgrade to Fibre 500 VOIP?
If so this means I can do away with the extra TP Link router as Hub 3 has ethernet ports.
Q2 : If I change to WiFi Hub 3 with green phone socket, does this do away with the need for Digital Voice Adapter as the phone plugs into the hub?
Q3 : What model of Sagemcom is the latest WiFi Hub 3 with green phone socket, ( is it FAST 5359 or 5364 or something else ) I would like to get a link to the full user manual for this item. Have emailed Sagemcom but no response.
Thank you in advance.
04-12-2025 10:09 AM - edited 04-12-2025 11:20 AM
Hi there @Elgin19, thank you for reaching out.
1. Wi-Fi hub 3
2. No, as the phone can connect directly to the new hub.
3. The latest model of the Sagemcom WiFi Hub 3 with a green phone socket is the Sagemcom FAST 5364. It is commonly referred to as the TalkTalk Wi-Fi Hub. The FAST 5359 model is also notable as the latest.
Here are links to the user manuals for both models:
Sagemcom FAST 5364 User Manual – This manual is for download and provides detailed information on setup and configuration.
Sagemcom FAST 5359 User Manual – This is also available for download but might have fewer details compared to the 5364.
@KeithFrench please advise further or add if I missed any info, thanks🙏.
