Using your own router with fibre 500
Robsy1
Message 12 of 12
I'm having full fibre 500 installed in a few weeks. Does anyone know if I can use my current TP link archer c64 router instead of the supplied Amazon eeros 6? Is the ONT box a modem that can be plugged straight into my current router?
11 REPLIES 11
Message 1 of 12
If you go through the help that I have offered you, then I might be able to get this resolved for you.
Message 2 of 12
Thanks for the reply, I will go through all the troubleshooting after the weekend. I've disconnected all other WiFi devices, smart home etc too test just the eero WiFi. Wired connections euro fine speed is good, laughably this modern tower only has one ethernet port but that can be dealt with. The WiFi signal from the eero is simply not great. Didn't reach my back garden at all, getting a weak signal in living room and intermittent signal in the kitchen. I think the only answer is going to be mesh extenders but I will try messing with setup. It's disappointing as my old c64 archer router had great signal over all floors to all rooms and the garden.
Message 3 of 12
I haven't managed to find where to Input those settings in my current router. I'm fairly technical but just couldn't find the right page.
Message 4 of 12
Hi @Robsy1
@Gliwmaeden2 has asked me to help you.
However, other factors should be investigated first. When this happens, what is the status displayed in the app for the internet connection? Do you have any wired connections & if so, how do they perform?
Whilst the eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use. It is possible that you may also need to purchase additional eero nodes as it is supposed to operate as part of a mesh system. I can help with any of this. However, I would suggest that you follow my help to find out what the root cause of the problem is, before throwing money at it.
Gliwmaeden2
Message 5 of 12
FIBRE500 is automatically set up to work with the Eero, so that's why it's working even if the reach is not what you hoped for.
@KeithFrench may be able to advise you as to the best route forward. Settings for a NON Talktalk router are given in the link you were sent by ShoreRam, but they don't distinguish between FTTC and FTTP. Maybe the instructions should work for both -did you try them, @Robsy1 ?
Staff will not be back on here before Monday. If you need support other than what fellow customers can offer you over the weekend, phone support is open today till 6pm, and there is live chat available both days:
Message 6 of 12
Would you happen to have a link to your router or just the model number?
Robsy1
Message 7 of 12
Could someone from talktalk supply the details I need to get my router working as when connected to the ont via ethernet it does not work. I've had to use the eero router which has awful WiFi coverage compared to my c64 archer
ShoreRam
Message 8 of 12
To add - While there are instructions on how to set up a non TalkTalk router you should find that you don't need to do anything and your router will figure it out but if there's any issue, those instructions are here:- https://community.talktalk.co.uk/t5/Articles/Set-up-a-non-TalkTalk-router/ta-p/2205383 Keep hold of your Eero though as TalkTalk may want it back and it's no use to you outside of the TalkTalk world.
As I've mentioned elsewhere, I use a Unifi router and it set itself up in seconds, it's way my powerful with much more functionality than an Eero but the Amazon devices certainly work for the non teccy user.
50 days offline and counting
Message 9 of 12
No worries. If you do have any issues, you know where we are!  🙂
Message 10 of 12
Great to hear, thanks for the reply.
Message 11 of 12
The ONT effectively works as a modem as far as a router is concerned and yes, you can continue to use your own if you wish.
Anonymous User
