on 21-01-2025 04:25 PM
I'm having full fibre 500 installed in a few weeks. Does anyone know if I can use my current TP link archer c64 router instead of the supplied Amazon eeros 6? Is the ONT box a modem that can be plugged straight into my current router?
5 hours ago
I haven't managed to find where to Input those settings in my current router. I'm fairly technical but just couldn't find the right page.
6 hours ago
Hi @Robsy1
@Gliwmaeden2 has asked me to help you.
However, other factors should be investigated first. When this happens, what is the status displayed in the app for the internet connection? Do you have any wired connections & if so, how do they perform?
Whilst the eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use. It is possible that you may also need to purchase additional eero nodes as it is supposed to operate as part of a mesh system. I can help with any of this. However, I would suggest that you follow my help to find out what the root cause of the problem is, before throwing money at it.
8 hours ago
FIBRE500 is automatically set up to work with the Eero, so that's why it's working even if the reach is not what you hoped for.
@KeithFrench may be able to advise you as to the best route forward. Settings for a NON Talktalk router are given in the link you were sent by ShoreRam, but they don't distinguish between FTTC and FTTP. Maybe the instructions should work for both -did you try them, @Robsy1 ?
Staff will not be back on here before Monday. If you need support other than what fellow customers can offer you over the weekend, phone support is open today till 6pm, and there is live chat available both days:
11 hours ago
Would you happen to have a link to your router or just the model number?
16 hours ago
Could someone from talktalk supply the details I need to get my router working as when connected to the ont via ethernet it does not work. I've had to use the eero router which has awful WiFi coverage compared to my c64 archer
on 22-01-2025 08:13 AM
To add - While there are instructions on how to set up a non TalkTalk router you should find that you don't need to do anything and your router will figure it out but if there's any issue, those instructions are here:- https://community.talktalk.co.uk/t5/Articles/Set-up-a-non-TalkTalk-router/ta-p/2205383 Keep hold of your Eero though as TalkTalk may want it back and it's no use to you outside of the TalkTalk world.
As I've mentioned elsewhere, I use a Unifi router and it set itself up in seconds, it's way my powerful with much more functionality than an Eero but the Amazon devices certainly work for the non teccy user.
on 21-01-2025 05:13 PM
No worries. If you do have any issues, you know where we are! 🙂
on 21-01-2025 05:00 PM
Great to hear, thanks for the reply.
on 21-01-2025 04:35 PM
The ONT effectively works as a modem as far as a router is concerned and yes, you can continue to use your own if you wish.
