on 16-10-2024 03:23 PM
I have an Email to Regiter for a free trial of the new Wifi 3 hub. looking at the pictures of it, it looks identicle to my router which is "FAST 5465-2.ta. Can you tell me what if any is the difference, as my router is running 151mbs and VOICE. At the moment very stable "FinguresX
MikeS86
on 17-10-2024 07:19 AM
Hi MikeS86
Please can you contact the trials team in the email you have received, they can discuss this with you.
on 16-10-2024 10:37 PM
Hi Ferguson,
Have TalkTalk stopped using the EERO6 router ? and my first query was, the new WIFI hub3 they are testing out , what is the difference in performance from the FAST 5465-2.ta router I am using, or is it that new you have not come into contact with one.
MikeS86
on 16-10-2024 03:34 PM
No, just , if I was interested to fill in a Regiter form and they would check my elibility
on 16-10-2024 03:26 PM
Did the email not maybe ask that you did not share the details at this stage?
Your current service seems perfectly well served by your current Hub.
