on 09-08-2024 08:57 PM
When I try and follow a website link from Google on my iPhone I get an error message saying can’t open or website unavailable. Turn the WiFi off and no problem. This only happens when on my home WiFi donuts obviously a TalkTalk or eero problem
on 10-08-2024 05:45 PM
You're welcome. I have not delved into Eero Secure, perhaps there are options to allow certain sites etc?
on 10-08-2024 04:40 PM
Will do, thanks for all your help👍🏻
on 10-08-2024 04:25 PM
It is a content-blocking service, which a lot of routers do not have. To be 100% sure of the implications of doing this though, you would need to contact eero themselves.
on 10-08-2024 04:21 PM
So I followed the steps above, no joy, however I’ve returned it to default dns but left off the advanced security and it works, must be eero’s security blocking everything from Google? 🤷♂️ is that a risk leaving off the security ?
on 10-08-2024 03:31 PM
From the eero website:-
From the eero app,
Tap Discover
Tap eero Secure
Tap Advanced Security to toggle the feature on or off.
on 10-08-2024 03:22 PM
I’ve had a look but It won’t let me change the DNS settings unless I disable eero secure features? How do I do this? (Sorry, not very tech savvy, in case you hadn’t guessed😉)
10-08-2024 02:53 PM - edited 10-08-2024 02:53 PM
Have you tried changing your network DNS servers within the eero app?
To change the network DNS servers from the standard TalkTalk DNS servers to something like Google DNS (8.8.8.8 and 8.8.4.4) as an example, do this:-
Open the eero app.
Tap on Settings, then select Network Settings.
Tap on DNS.
In the DNS screen, change ISP DNS (Default) to Custom DNS.
Input your desired IPv4 and/or IPv6 DNS Server addresses.
Tap Save in the top right corner of the screen.
This will reboot your network in order to propagate the settings across your devices.
on 10-08-2024 01:56 PM
Works fine, in fact if I turn off the WiFi on my phone and reload it the page from Google it works without issue. It’s only when I follow a link from Google and only when connected to my home WiFi🤷♂️
on 10-08-2024 11:09 AM
What happens if you try to get to one of these sites, if you enter the address for that site in your browser, rather than going via Google?
on 10-08-2024 07:14 AM
Hi, thanks for answering. Yes all devices and yes we have the eero router
on 09-08-2024 10:33 PM
Does this affect all WiFi-connected devices, or just one? I assume from your post that you have the eero router?
