White Light but No WiFi
Reenz
Message 8 of 8
Since 2 days it keeps dropping, done the hard reset and switch off for 30mins.
Solid white light but no connection . Works for a short period and then drops again.
Vibes
7 REPLIES 7
Message 1 of 8
Hi @Reenz
This is the latest update on this fault.
Update 8:40PM  December 17th 2024 - Our team are in the process of applying a solution to all impacted Wi-Fi Hubs and aim to resolve this by tomorrow morning.
Message 2 of 8
@Reenz, updates are on the Service Status Dashboard:
https://community.talktalk.co.uk/t5/Service-Status-Dashboard/bd-p/service
Message 3 of 8
There’s still no fix ?
Vibes
Message 4 of 8
It’s saying communication error with the gateway
Vibes
Message 5 of 8
Hi @Reenz
Apologies for this.
Our engineers are investigating this issue and they have asked if you can try the below:
Change your router DNS settings to use Google DNS.
  • Open your web browser, type http://192.168.1.1 into the address bar and press Enter
  • Enter the username admin (in lowercase) and password (you'll find this on the removable settings card on the back of the Hub, and select OK
  • Select See internet settings
  • Select Manage advanced settings
  • Select TalkTalk WiFi Hub
  • Select DNS Tab
  • Make sure ON is enabled
  • Add Primary and Secondary DNS Servers ( Primary = 8.8.8.8  Secondary = 8.8.4.4 )
  • Select Apply
Please note ;  If you currently use any Homesafe services such as Homework Time etc.  This will not work whilst you have the DNS set to Google.
Message 6 of 8
Hi @Reenz
Apologies for this.
I think this may be related to a current fault that our engineers are investigating - (white light on router but no connection) I'll post back here as soon as I receive an update from the team investigating this.
Gliwmaeden2
Message 7 of 8
Thanks for starting your own thread, @Reenz.
Remember to complete your community forum profile details. Staff need this to identify your account and check your specific line.
Go via your avatar; settings, drop down menu.....add your Talktalk phone number or account number in Personal Information. Scroll down to find the button to SAVE CHANGES.
