YALE alarms do not work with Eero
STEPHENMAK
Message 53 of 53
My Yale HSA 6610 alarm worked perfectly for years until I installed Full Fibre 500 with an Eero router a few days ago. I have spent hours with Talktalk customer care and web chat who seem oblivious to the problem and Yale are adament that it is due to the Eero router. I have followed all the advice including changing the DNS to 8.8.8.8 and 8.8.4.4. I have opened the ports 5222 and 8765. I have tried Legacy mode even though it is an ethernet connection not a WIFI connection to the alarm hub. I have reset the Eero, I have reset the alarm hub.
It's incredibly frustrating as well as annoying. Why isn't there a fix for this. It has been going on for years and Yale say it is a compatibility issue which can be overcome. I feel letdown by talktalk.
52 REPLIES 52
Message 41 of 53
I updated my profile yesterday and confirmed at the same time.
Message 42 of 53
And Michelle is waiting for you to update your community profile and confirm when you have done so.
Message 43 of 53
Hi , You mentioned maybe I was being a little harsh with Talk talk. Let me update you. 2 days ago I sent Yale an email. It was sent to the same person who has been helping me for the last few days. Each time I contact Yale, I am able to speak to him personally. He is polite and sends me emails with instructions and updates. The latest is he will escalate the issue to a higher technical level of support when all other avenues have been exhausted by Talktalk. Yale have not washed there hands of the matter. All they are saying is that the alarm is not faulty.
They have also offered me a substantial reduction in price for a new different Yale Alarm if the issue cannot be resolved.
Contrast this to Talktalk customer care : 2 long sessions on the chat helpline, one long phone call, and an attempt to speak to Eero only to be cut off because by then it was nearly closing time.
I was also told by the Talktalk operator that as all my other devices were working, then there was nothing wrong with the Eero. Only when I mentioned escalating the issue, did she attempt to put me through to the Eero Technical Team.
In the process I have spoken to about 4-5 different people each time having to explain the problem from scratch.
The last I heard was a message from Michelle at Customer care who said she was waiting for advice from a colleague. As of today I am still waiting for further advice from her.
Message 44 of 53
Hi @STEPHENMAK
  • Name
  • Telephone number or Account number
  • Alternative contact number
Message 45 of 53
I've asked one of my colleagues for advice and I'll post back as soon as I receive a reply.
Message 46 of 53
So have you got alterenative DNS servers set up now e.g. Google, or OpenDNS?  I use a mix of both.
Message 47 of 53
Yale told me that they had come across this problem and the only way to get around it is to change the settings which talk talk were supposed to do. As it happens I was assured by one of their support staff that he had done this. However in my Eero app everything was still the same so I changed them manually.
With regards Yale there is nothing they can do as the alarm hub can only be connected with an ethernet cable.
Message 48 of 53
Just rewinding a bit, have you changed the DNS settings on the eero itself? You need to disable eero security to do this.
Message 49 of 53
If it was me I would be disappointed at the response from Yale. How many millions of eeros do you think there are in operation? Anyway, do keep us posted, but I think you're being a wee bit harsh on TalkTalk at the the moment.
STEPHENMAK
Message 50 of 53
I will try Eero technical support again but I still can't believe that they can't fix this . Apparently Yale told me they have millions of these alarms in operation.
STEPHENMAK
Message 51 of 53
After about 45 minutes with Talk talk support, they insisted that as the Eero worked with all my other devices then there was nothing wrong with it. It was only when I mentioned terminating my contract and complaining that they offered to put me through to Eero Technical support. I waited 20 minutes and than at 5:40 I got a message saying they were now closed !
I have spent literally hours trying to get it to work.
Message 52 of 53
Have you tried reaching out to eero support directly? But if Yale are washing their hands of it then that seems poor from them.
