on 16-10-2024 10:50 AM
Yale Alarm Hub suddenly offline since this morning. Having powered off the Yale hub, EERO and ONT for 30 minutes to reset, the Yale hub says offline.
I had this problem when setting up the EERO in Jan/Feb 2024, but changed the DNS to 8.8.8.8, which has been fine ever since, so confused as to the sudden issue today.
The Yale Hub shows as a connected device on the EERO app, with no obvious issue.
Any ideas please?
on 16-10-2024 02:26 PM
Do you know if there's been any recent updates on the hub?
on 16-10-2024 01:44 PM
Yes, it's still offline from my end.
on 16-10-2024 01:42 PM
Thanks. It looks OK from our side, is it still showing offline?
on 16-10-2024 01:03 PM
Hi Chris,
It is now connected and switched on. It shows as "Climax Technology Co". Thank you.
on 16-10-2024 12:20 PM
OK, is it currently connected and switched on?
on 16-10-2024 12:02 PM
Hi Chris,
It's an ethernet connection. Thank you.
on 16-10-2024 12:00 PM
OK thanks. Does the Yale hub connect to the eero by wifi or Ethernet cable?
on 16-10-2024 11:34 AM
Hi Chris,
EERO app is still showing custom DNS as 8.8.8.8 for IPv4 Primary & Seconday.
on 16-10-2024 11:29 AM
Hi Adam16031,
Just a thought but have you checked that the DNS servers haven't changed back to the defaults?
on 16-10-2024 10:56 AM
@Adam16031 wrote:Yale Alarm Hub suddenly offline since this morning. Having powered off the Yale hub, EERO and ONT for 30 minutes to reset, the Yale hub says offline.
Any ideas please?
@Gondola I've seen your name pop up on a couple of threads, if you could shed any light please?
Just to confirm, my Yale Hub is a wired connection to the EERO.
