Yale smart alarm offline
amos19
Message 50 of 50
Hi just gone on to fiber had new eero modem my yale smart alarm worked for couple of hours, then the modem done a update now the alarm is offline and i cant reconnect i tried rebooting the alarm and modem but us still off line, any advice or suggestion's would be great, Thanks
49 REPLIES 49
Message 41 of 50
Hi @amos19
I think I have found the right manual; it says smart home alarm & further down in it, it mentions the smart Hub 2.0.
Is it an SR-310, SR-320, SR-330 or the SR-340?
I have found this page about the lights:-
Alarm lightsAlarm lights
Please can you clarify:-
  • With the Ethernet cable connected, is the top light green?
  • What state is the fault status light in the middle?
However, the manual does not mention what the bleep code means. I need you to contact Yale support to find out exactly what these bleeps mean.
Do you have just the one eero & does it connect directly to the one remaining Ethernet port?
Message 42 of 50
Hi @amos19
I have found this on the Yale website - the Yale Sync Hub, not a Smart Hub:-
https://yalehome.co.uk/yale-sync-hub/?srsltid=AfmBOoqLGsEcedJpcrPU1BOoJFKh5lRl-RFCWfuqRNWJXEInYHnobK...
Is this the product that you have? If not, can you please provide me with a link to it so that I can try & download a user guide for it.
Message 43 of 50
OK thanks for this. I will need to do some research online, but it may not be until tomorrow now.
amos19
Message 44 of 50
Yale say the hub has no faults they say contact TT, its yale smart hub 2.0 once i connect the ethernet cable it constant bleep when i power up its got amber/yellow light in middle connect the ethernet cable light goes off but constant bleeping every 5 seconds double bleep but it did work till the very minute the modem done update then when off line
Message 45 of 50
I can only go with what other customers have told me, except for the fact that none of them so far have been an eero issue; they have been Yale problems.
Have you spoken to Yale support?
What model of Yale do you have & what lights are on it?
Message 46 of 50
Thanks for your reply, I dont have any key fobs only 1 key pad on entry but dont understand why it stopped straight after modem updated
Message 47 of 50
In all the other cases I have dealt with, it has been the Yale that was at fault. One of the solutions I sent you talks about lots of key fobbs being registered with the Yale app.
amos19
Message 48 of 50
Hi i got new battery but still the same, I didn't think it was battery as when i first setup the modem it all worked once the eero modem done software update it stopped working after the update?
Message 49 of 50
Hi @amos19
There have been a few posts about a Yale alarm (particularly the Yale HSA 6610) & an eero not working together. However, it does not look like the eero was at fault.
Is the orange light on your Yale alarm bleeping by any chance? If so, the Yale would appear to have a flat battery:-
"A flashing orange light or beeping on a Yale alarm typically indicates a fault within the system, most likely a low battery or a tamper alert on one of the sensorscheck the fault log within the Yale app to pinpoint the exact issue and address it accordingly. "
If the green light signifies it is connected. However, does this mean it is just connected to the eero or some Yale system online?
I think this final post was the solution here:-
"Just one last update , maybe to help other Yale alarm users in future.
So I finally got my Yale alarm system working. In spite of all the changes in settings and testing both the Eero router as well as the Yale hub, I still couldn't get any key fob or keypad to set the alarm even though the Yale hub was connected and showing a green light.
I decided it must be a radio frequency issue ( all the devices are linked by radio frequency not WIFI or Ethernet. The ethernet connection means that the alarm can also be controlled by the Yale app. But disconnecting it , will still leave the alarm working using radio frequency)
I discovered that although I had 18 devices on the app, none of them were paired. When I paired a new spare PIR, all the other devices disappeared from my list in the Yale app. Although they were supposedly paired, in reality they were not explaining why nothing worked. I proceeded to pair all the other devices and now everything is working including notifications.
I can't explain why this happened when I upgraded to Fast fibre with the Eero but it did and the solution was straightforward ( still needed the settings set to the Yale recommendations) I am amazed nobody at Yale suggested it."
The above posts are from this thread that I had a lot to do with:-
https://community.talktalk.co.uk/t5/Full-Fibre/YALE-alarms-do-not-work-with-Eero/td-p/3092829
The information below is provided by TalkTalk, for confirmation, please contact @Debbie-TalkTalk or @Lorrainef.
If you need further help or if we need to take any details such as personal information about your account like phone numbers, account numbers, etc, one of the TalkTalk team will jump in and help out.
