sagemcon fast 5464 router
FarmingMartin
Message 44 of 44
i have been sent a replacement Sagemcon Fast  5464 router which has a differant version  to my previous one, due to the stand breaking so i am asking which one is the latest version and which one I should use as i can swap over the stands.
the two router say on the back
Fast 5464-2.t4
Fast 5464-3.t8
thanks
43 REPLIES 43
FarmingMartin
Message 41 of 44
I have now tried both routers and am still having device connection issues. I was sent a new router as I was told the old one may have a fault, which has now been diagnosed as an outside cable issue, but if I connect the old one everything works a lot better than with the new ones.
The old one is Hauwei HG633
There is still an issue which openreach are supposed to be sorting out but I don't know when, as I have not heard anything from either talktalk or openreach regarding when they are coming back to fix it. Internet now been playing up for nearly a month, not happy seriously thinking about ditching talktalk if they don't do something soon.
Message 42 of 44
Hi @FarmingMartin
It's the 2nd one in your list. If the stand is broken then I can replace the router.
Message 43 of 44
I would have thought that the latest model has the higher numbers.
