slow speed to computer
paulcs
Message 11 of 11
I have full fibre 150. I get that speed from the modem but i can only get speeds of around 66bps to my lap top.
I have tried differnet rooms in the house plus  having the lap top right next to the router.
Is this normal speeds or do I need a new router?
10 REPLIES 10
Message 1 of 11
I've ordered the router, it should be with you within a couple of days
paulcs
Message 2 of 11
Yes pease send me a new router. Thanks Paul
Message 3 of 11
Would you like us to send another router to test with?
paulcs
Message 4 of 11
Thank you for your quick reply.
I can confirm that i have reset the router and set it up agian but still only getting speeds of 64mps and 156 mps to the main  box
Message 5 of 11
Thanks for confirming. Have you tried factory resetting the router and then re-set this up again please? If there is no change following this then we can send a replacement router for testing purposes to rule this out.
paulcs
Message 6 of 11
H
Good Morning
I can confirm that I am currently using the Wifi hub router. Which was supplied by City Fibre.
It is a older version hub and not the latest Erro one.
Message 7 of 11
Good morning,
I'm sorry to hear this. Can I just confirm, are you currently using the Wifi Hub router?
Message 8 of 11
Hi @paulcs thanks for trying. The team will run their diagnostics for you tomorrow
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
paulcs
Message 9 of 11
It is a new laptop and when i connect with the ethernet cable i only get 42mps. I still get 156 mps  from the
modem. I have also disconnected my landline phone
Divsec
Message 10 of 11
Hi @paulcs or you might need a new laptop? How does it go when connected with ethernet cable?
Either way your post has been escalated and you should hear tomorrow
