slow speed to computer
paulcs
Message 11 of 11
I have full fibre 150. I get that speed from the modem but i can only get speeds of around 66bps to my lap top.
I have tried differnet rooms in the house plus  having the lap top right next to the router.
Is this normal speeds or do I need a new router?
10 REPLIES 10
Message 1 of 11
I've ordered the router, it should be with you within a couple of days
paulcs
Message 2 of 11
Yes pease send me a new router. Thanks Paul
Message 3 of 11
Would you like us to send another router to test with?
paulcs
Message 4 of 11
Thank you for your quick reply.
I can confirm that i have reset the router and set it up agian but still only getting speeds of 64mps and 156 mps to the main  box
Message 5 of 11
Thanks for confirming. Have you tried factory resetting the router and then re-set this up again please? If there is no change following this then we can send a replacement router for testing purposes to rule this out.
paulcs
Message 6 of 11
H
Good Morning
I can confirm that I am currently using the Wifi hub router. Which was supplied by City Fibre.
It is a older version hub and not the latest Erro one.
Message 7 of 11
Good morning,
I'm sorry to hear this. Can I just confirm, are you currently using the Wifi Hub router?
Message 8 of 11
Hi @paulcs thanks for trying. The team will run their diagnostics for you tomorrow
paulcs
Message 9 of 11
It is a new laptop and when i connect with the ethernet cable i only get 42mps. I still get 156 mps  from the
modem. I have also disconnected my landline phone
Divsec
Message 10 of 11
Hi @paulcs or you might need a new laptop? How does it go when connected with ethernet cable?
Either way your post has been escalated and you should hear tomorrow
Anonymous User
