on 27-04-2022 04:58 PM
Hi all,
Installation is due in a week, and I'm looking to keep my current router, and just shift it in to bridged mode.
I've got a TP-Link VR900, and one the reasons I want to keep it is the fact it has multiple ethernet ports (I currently have my TV, my Xbox and a powerline adapter plugged into it), and I know the Eero only has 2 ports, one of which is needed to connect to the fibre modem.
I know i could use the eero, and plug in a small switch, but I'd rather stick with one device rather than two.
Anyone tried this?
Cheers
on 04-05-2022 04:31 AM
That's a pain, the vr900 does appear to have a gigbit wan port - so presumably is capable of handling the fttp speeds.
I'm not particularly techie when it comes to routers, once set up I like to forget they`re there [until they go wrong] so can't offer any advice.
I did need to replace one cable though as it was quite old, possibly faulty and wasn't up to the job - I replaced them all with newer to rule out any future issues with them.
The Asus modem/router I got only about a month prior to choosing full fibre as my old 5yo router was really starting to show problems with dropouts and general oddness - otherwise I would have just got a router rather than modem/router but it works OK.
I did do a full reset eventually and went through the setup procedure and made sure nothing was affecting the connection, QOS etc and went through all the settings manually.
Sorry yours isn`t performing properly but I can`t think of what to suggest but I know it's annoying and frustrating.
on 03-05-2022 11:07 PM
well, i managed to get it working....eventually. And not particularly well.
On average i was only getting 20-25% of the speed i was seeing on the eero, so
its going to be a backup router for now.
Mildly annoying - running a couple of extra devices over WiFi now (i do have a wee noddy switch i could
use, but thats just yet another device plugged in, so no. at least for now.)
on 03-05-2022 08:35 PM
I was worried at first but got my Asus (DSL-AX82U) working OK after altering a couple of settings I didn`t know existed as it was still quite new to me.
Similar problem - needed more ports...and control.
Full speeds with no issues at all (which was fortunate as I couldn't even get the eero to set up at all !)
28-04-2022 08:02 PM - edited 28-04-2022 08:03 PM
no worries @bigkenny - thats the sorta mistake i make most days....
cheers
on 28-04-2022 12:01 PM
Yes sorry about that yes it was for normal FTTC setup (router) and as others say for your FTTP connection just link to WAN port.
I just sent it not realising it was a FTTP question, sorry again
on 27-04-2022 10:51 PM
on 27-04-2022 08:54 PM
Thanks for the response Kenny.
As far as i can tell though, those instructions are for ADSL or FTTC, not FTTP.
Unless I'm completely misunderstanding them, of course 🙂
on 27-04-2022 08:49 PM
