Home Phone
All incoming calls showing as 'withheld'.
Stefan4
Message 15 of 15
Since I cancelled CallSafe all incoming calls are showing as 'withheld'. Raised the issue over the chat lines and was assured that ptroblem would be fixed after 24 hours. 48 hours now passed and problem still persists!
Caller display is set on.
14 REPLIES 14
Message 1 of 15
Stefan4
Message 2 of 15
Caller Display is now working. Numbers are displaying correctly.
thanks for your help.
Message 3 of 15
Can you test caller display in a few hours the network team have re-added it now.
Stefan4
Message 4 of 15
Have just checked my home phone details and Caller Display is now showing as not set.
Should I now reset it? or is the fault still being investiigated.
Message 5 of 15
Hi Stefan4
The  issue has been raised , looks like the calling features are not transferring over when Voip is added.
I have logged the fault for you.
Stefan4
Message 6 of 15
Problem still persists.
Have noticed on the community that other users seem to be experiencing the same problem!!
Message 7 of 15
Ok we might have to  turn off caller display and then re-add it, if that doesn't work then we can log it as a fault.   I will do it now, can take a few hours to kick in so retest either late tonight or tomorrow then let us know.
Stefan4
Message 8 of 15
CallSafe is showing as off.
I asume it is working ok because calls are coming through but still showing as withheld.
Message 9 of 15
Hi @Stefan4
Can you test, the callsafe issue has been resolved and is showing as off.
Let me know.
Message 10 of 15
Hi Stefan4
It looks like the request to remove callsafe has not completed, So I have asked the ops team to fix the problem.
Will let you know when I get an update.
Sorry for any inconvenience
Stefan4
Message 11 of 15
Yes. Have used Chrome and Microsoft Edge with same result.
Message 12 of 15
Does this also happen if you try a different browser?
Stefan4
Message 13 of 15
I did try to switch off Caller Display and switch back on but system would not let me.
Still shows as ON
Message 14 of 15
Hi Stefan,
I'm sorry to hear this. Can I just confirm, have you also tried removing the Caller Display service in your My Account and then re-added this again?
