Home Phone
Call Safe is OFF . How do I bar numbers when using 14258 is shown as not available?
jotoho1
Message 5 of 5
Silent caller & when I return call phone does not ring. Rang 14258 & "service is not available"  ????
4 REPLIES 4
Message 1 of 5
Hi @jotoho1
The first thing we will do here is to remove last caller barring and then re-add it where you given that option when you called ?   if not we can do it but we will need to confirm some security first.
I have sent you a PM on the community.
jotoho1
Message 2 of 5
The only option that expands is Calling Circle ,all else is just a summary & cost. I checked my bill & at the bottom it shows  :-
Included as standard:
Because we like to give you the very best value, these services are included in your package.
Caller Display
Last caller barring.
Am I the only one turning into an Oozlum bird ?
jotoho1
Message 3 of 5
I spent 2 hours yesterday & got nowhere. I log in & menu  does show N/W & Conns. I click on that & 3 options are My Conn or My TT N/W Status or Prof & setts. Pressed last one shows  My Tel Setts pressed for that & that shows a list of the items in MY Account. Whichever I select merely shows the cost for that item. Nowhere is there any link to last caller barring ?
Bemused !
Message 4 of 5
Can I just confirm, do you have Selective Call Rejection (Last Caller Barring) set up and active in your My Account?
Using Selective call rejection (Last Caller Barrin... - TalkTalk Help & Support
