Home Phone
CallSafe not activating afer migration to Full Fibre / VOIP Digital Voice
AlastairMutch
Message 29 of 29
I've just moved from a copper landline to Digital voice and full fibre.  I had a list of blocked numbers that I could add to simply enough via the phone on the old landline but...
When I try to activate CallSafe to give me a similar service via the voip landline it gives me an error message and tells me to call 150. Having spent 30 minutes on the phone with a support person who really didn't understand what I was asking about I'd rather not do that again.
Is there a way to get it activated?
Alastair
28 REPLIES 28
Message 1 of 29
Thank you @Gliwmaeden2
Message 2 of 29
Talktalk support only replies to the original poster, @Padger.
Please return to the message board and click on start a topic to begin your own thread.
Padger
Message 3 of 29
O.k. So am having problems with no callsafe on my account.
A lot of info suggests its due to Voip and FTTP fibre changeover ( respectfully Talktalk teams as well)
I would like to suggest it definately and categorically cannot be.
The reason being I went live with FTTP 150 mbs and VOIP telephone calls over 18 months ago. And Callsafe worked perfectly fine from then and was showing and accessible in My Account and usable (ability to add and block nos)
Contract run out and since taking a new 24 month contract of exactly the same FTTP 150mbs and Voip calls last month (Sept 2025)
The Callsafe has disappeared from my account. So it cannot be the FTTP or VOIP!!
So it has to be something that takes place on the new contract update to the TalkTalk site.
So I would suggest there is a bug causing a confliction when contracts are updated.
Comments??? TalkTalk support team welcome.
Message 4 of 29
Hi there, I am sorry for this; I see on my end that there is a follow up on your case for today between 14:00-16:00. Kindly bear with us as our full fibre team will look into this for you, thanks.
Message 5 of 29
Sorry I thought that I was clear in my previous post. I called the support number as suggested and spent a long and frustrating 4 hours in the on-line chat with the full fibre support team where multiple technicians tried, unsuccessfully, to diagnose and/or fix the problem with CallSafe. At the end of the unsuccessful call they marked the support issue as resolved - it isn't.
I have given up, raised a formal complaint about the very poor level of support and lack of technical knowledge resulting in a very frustrating experience. I will not waste any more time requesting a fix from TalkTalk technical support on this issue.
It's a pity as the full fibre service otherwise is very good and my previous experience with TalkTalk support has been good too.  Not this time though.
Alastair
Message 6 of 29
Hey @AlastairMutch, I understand that this matter is with regards to CallSafe not activating after migration and our Full Fibre team was handling this issue for a better resolution.
Just to double check, have/has the team got in touch with you recently?
Message 7 of 29
.. and just to add fuel to the frustration I see that the technical team have marked my issue as "resolved" according to the text just received from TalkTalk.
You can't make this up.
Alastair
Message 8 of 29
I called the telephone number and eventually got through to the Full Fibre support team - having been requested after calling the number to switch to SMS text and then to on-line chat via a link.  The first technical expert, Mitesh, reviewed the information provided and then appears to have immediately cut me off as I got kicked back to the initial on-line chat bot. I'll put it down to finger trouble at his end rather than the "too difficult" option because I'm a nice person. It may just be that the timeout on the on-line chat is too short and times out while waiting for the agent to reply.
The bot reconnected me when I replied - this time to a second expert, Prachi. I repeated the fault description for him and... he sent me the page that explains how to use CallSafe.  What a complete and utter waste of time given that I had already explained what I had done to try and activate it.  The support technical knowledge seems completely absent and limited to working through a script.
He eventually passed me on to what I guess is second line support - Sachin.  He then asked sensible questions to identify the hardware that I had and then tried to reconfigure the VoiP adapter remotely. Finally someone who understands the system? However after doing the Power off, wait, Power on dance a few more times we were no further forward.  He did say that the checks for Digital Voice configuration can take up to five minutes so we waited. Then tried it again - no change.
Sachin then passed me on to customer support and billing - Neha. She took details of the fault and then said she would pass me on to their dedicated team. So now I'm right back at the start again and almost three hours in - this time chatting with Shruti.  He restarted the original script asking about the fault.  At this point I gave up having completely lost the will to live. I asked Shruti to record my call as a formal complaint regarding the support service. He transferred me to Anas to whom I have requested that a formal complaint be raised.
I've now spent yet another 3 hours of my life on the chat with technical support with zero progress and apparently zero understanding of how to fix it.  This level of support is just awful - no, far worse than that!   It reminds me of why I left Virgin Media several years ago and would never go back.
It's best to abandon Talk Talk's CallSafe service and buy a hardware box to block calls, I think.  Life is just too short.  If I can't get it fixed as an "IT expert" then what chance do normal customers have.
The Talk Talk website also has this page: https://service.talktalk.co.uk/CallSafe which says "CallSafe is not available with digital voice".  Since some people already have it working this also seems wrong.  Hey ho.
Other than the CallSafe the rest of the full fibre service from Talk Talk seems pretty good so far. It's just a shame that the technical support / fault finding is so abysmally terrible with anything other than the normal user problems.
Alastair
Message 9 of 29
@AlastairMutch, did you call the Full Fibre team yourself as suggested by @angelique-TT?
Chris-TalkTalk no longer works here.
Message 10 of 29
Hi Chris,
Yes I tried switching everything off for 60 minutes and turning it all back on again. No change - I still get an invite to enable call safe on first call and then a "Sorry" message if I attempt to enable it for a second time a bit later.
I note that the website doesn't have any options to manage Call Safe in the Add-ons section despite showing it as enabled for my account.
Alastair
Message 11 of 29
Good morning. Please contact our full fibre team using the below contact details so that they can look into this for you.
03451720074
Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed
-Angie
Message 12 of 29
Exactly the same.  Not activated and attempting to activate by dialing 1472 then 1 gives the error message.
Meantime I get a couple of scam calls a day.
Where is call safe implemented - in the VoIP / digital voice device or the home router or in your network?
Alastair
Message 13 of 29
Hi Alastair,
How has it been over he weekend?
Message 14 of 29
Still the same.
It seems to alternate from day to day.  Yesterday I dialed 1472 and, when prompted, dialed 1 to "enable call safe" I got the error message telling me to dial 150.
Today I tried again, dialed 1 to enable call safe and got a success message saying that it would be set up shortly.  I'm sure it will not...
Alastair
Message 15 of 29
Hi Alastair,
Can you just confirm that it's still not working today and I'll pass it over to our Future Fibre team and ask them to take a look
Message 16 of 29
It's an Eero router on full fibre 150.
Already tried a full reset.
Alastair
Message 17 of 29
Hi @AlastairMutch
You don't say what Router you have, but if it's the WiFi Hub 2, try a 10 second pin reset of the Router.  Can't guarantee it will work for you, but this action activated CallSafe for me when I had a similar issue some months ago.
Message 18 of 29
Selective call rejection is not available on VoIP / Digital Voice lines which is what I now have.
I used it for years on my old analogue service and it worked just fine.
I'll take whatever I can get to work now.
Alastair
Message 19 of 29
@AlastairMutch, is it worth trying Last Caller Barring instead?
You can't use it alongside Callsafe, but, if you block each dodgy number, you do find that the number of unwanted calls becomes minimal. Everyone else can get through.
https://community.talktalk.co.uk/t5/Articles/Using-Selective-call-rejection-Last-Caller-Barring/ta-p...
Message 20 of 29
Hi Chris,
Yes, scam calls are still getting through.
When I dial 1472 I get the "Welcome to call safe. To activate this service press 1" message. Nothing else.
If I press 1 I get a message "Sorry we can't help you at this time. Please dial 150"
So even it if appears to be on at your end it isn't working. I have no option to add or remove numbers from the blocked / accept list.
Alastair
