on 12-07-2024 01:06 PM
Sorry Michelle , the quick fix you suggested lasted about 24hrs I've now lost it again, but thanks anyway , I've switched it off again from my add ons and will try again tomorrow, obviously a fault with the lines.
on 23-07-2024 09:31 AM
Have our team made contact since our last post?
on 16-07-2024 12:23 PM
OK thanks, I'll pass it over to our network team and ask them to take a look. I'll let you know when I receive an update or they may contact you directly
on 16-07-2024 12:15 PM
Just "Incoming Call" with no name or voice notification .
on 16-07-2024 10:28 AM
OK thanks. What does it show now when you get an incoming call?
on 16-07-2024 10:22 AM
No, still not working this morning.
on 16-07-2024 09:28 AM
Hi popboffy1,
Hope your wife is OK and feeling better. Just to confirm, is caller display still not working this morning?
on 15-07-2024 08:18 PM
Been to hospital outpatients most of afternoon with wife , tried on my return, NOT WORKING.
on 15-07-2024 11:59 AM
OK thanks. Please let us know if the issue reoccurs
on 15-07-2024 11:10 AM
Hi Chris, it is working at the moment.
on 15-07-2024 11:00 AM
Thanks. I've made a change, can you please retest and let me know if it's now working
on 15-07-2024 10:13 AM
No Chris not working at the moment, tried three times yesterday over a six hour span, didn't work twice but did work on the middle try.
on 15-07-2024 08:13 AM
no problem, thanks
on 15-07-2024 08:05 AM
Hi Chris,
Unable to ascertain at present , wife poorly and still in bed, usually until 10ish, I'll give it a ring later and inform you one way or another.
on 15-07-2024 07:30 AM
Hi popboffy1,
Just to confirm, is it still not working?
on 12-07-2024 08:00 PM
Ooops it lasted 3hrs this time , it's off again , think we'll give it up as a lost cause.
on 12-07-2024 04:43 PM
Yes.
on 12-07-2024 03:46 PM
OK Caller Display back on didn't notice had to log out and then log back in to take effect, instruction wasn't very clear.
on 12-07-2024 03:26 PM
No can do, I have ticked to put on when I confirm it disappears, probably have to wait until my previous "Cancelled" instruction is rectified , I'll try again in a couple of hours.
on 12-07-2024 02:17 PM
Could you switch it back on in My Account and let me know when you've done this. I'll then take a look to see if I can see anything stopping it working on our side
on 12-07-2024 02:11 PM
No, as soon as I noticed it wasn't working, yet again, I followed Michelle's instruction to take it off and wait a couple of hours before turning it back on, which I did and it worked albeit for a short while,
