on 13-10-2023 12:19 PM
on 17-01-2025 05:06 PM
You will see that this an old thread. Please start your own topic if you want help.
on 17-01-2025 04:59 PM
I'm having the exact same problem and talking to Talk Talk has proved to be a waste of time. Their Tech support is rubbish.
Gave up trying to solve the problen in the end.
on 23-08-2024 07:42 AM
Hi 37ttcom
I’ve been in exactly the same boat as you for nearly two years.
Unhappy Bunny
on 18-10-2023 01:03 PM
No problem 🙂
on 18-10-2023 12:00 PM
Noted. Thank you.
on 18-10-2023 11:58 AM
OK thanks, I'll pass this over to our network team and ask them to take a look. I'll let you know when I receive and update or they may contact you directly
on 18-10-2023 11:39 AM
Yes Caller Display showing on My Account.
In anticipation of your question, still not working.
on 18-10-2023 10:19 AM
Apologies, I didn't intend to switch callsafe off, I'm not really sure how I did it to be honest, I triple checked that it was caller display that I was switching off so not sure how it's happened.
Just to confirm, is caller display now showing as on in your My Account?
on 18-10-2023 10:13 AM
No, still not working.
Whilst I appreciate your assistance, it would have been a good idea if you have told me before you switched Callsafe off so that I could make a note of the Blocked and Approved numbers. I have no record of previously Blocked numbers and now have to try and remember all the Approved numbers and re-enter them which is a pain and very time consuming.
Be aware that whenever I have experienced problems in the past, the fault has always eventually been located in the exchange. Also, in case it is relevant, I am still on copper here as fibre is not available.
on 18-10-2023 09:52 AM
Hi 37ttcom,
Callsafe should be back on now. Could you just check my account and tell me if Caller Display is showing enabled now
on 18-10-2023 09:30 AM
By the way, Caller Display still not working.
on 18-10-2023 09:29 AM
I have received your latest message and then, immediately afterward, another e-mail to advise me that my Call Safe had been switched off. I presume that was some thing that you were doing?
Can I switch Call Safe back on? Will this mean that I will now have lost all my barred and permitted numbers and will have to re-enter them all?
on 18-10-2023 07:51 AM
OK thanks, could you just leave it with me, I'm just going to try something else
on 17-10-2023 07:06 PM
Thanks for your recent messages. Unfortunately, nothing has changed.
on 17-10-2023 02:53 PM
I've removed it, I'll re-add it in 30 minutes
on 17-10-2023 02:47 PM
OK thanks. I'll try removing it and re-adding it
on 17-10-2023 01:51 PM
You will see from my original post that I have tried this before, in fact I have lost track of how many times. However, have tried it again today, but no change.
on 17-10-2023 10:30 AM
OK thanks. Have you tried removing it and re-adding it in My Account, if not then can you give this a try
on 17-10-2023 10:18 AM
No change I'm afraid. Still shows "Incoming call".
on 17-10-2023 07:42 AM
Thanks. I've made a change, can you please retest and let me know if caller display is now working
