Home Phone
Home phone faulty
Rondo2
Message 3 of 3
Have reported this previously, and TWO engineers said problem was outside the home.Noisy cracking noise then silence.It appeared fixed for a few days now it has gone again same problem noisy line then nothing.
RA Mackie
Message 1 of 3
Hi Rondo2
Do you still need help with this?
The line tests are clear - No faults detected.
Can I just check, did you previously test with a different phone at the test socket, with the router removed?
Message 2 of 3
Hi Rondo2
Anonymous User
