Home Phone
LANDLINE PROBLEM
MelodicEmu
Message 11 of 11
I'm getting a busy tone on my landline and I am unable to make or receive calls.
10 REPLIES 10
Message 1 of 11
I'm really glad to hear this and thanks for confirming 🙂
Message 2 of 11
My landline is working again. Thank you.
Message 3 of 11
The latest update is that the engineers have repaired the cabling and that the fault should now be resolved. Do you now have a dial tone/is the voice service ok?
Message 4 of 11
Thank you for the update
Message 5 of 11
There is an additional update to advise that additional cabling work is needed so we will continue to monitor for further updates from the engineers.
Message 6 of 11
Just a quick update to let you know that the engineers are currently working on restoring service now/resolving the cabling issues and I will check again at 1pm for a further update.
Message 7 of 11
Okay thanks for checking
Message 8 of 11
Hi MelodicEmu
I've completed another line test and this is clear. I have also checked another system and this is detecting a potential issue in your area, engineers have arrived on site to assess the cables for any physical damage.
We will check on this again later this afternoon for additional updates.
MelodicEmu
Message 9 of 11
Hi, Yes the phone is connected to the test socket. I have run two tests this morning and both have reported there is a fault.
Message 10 of 11
Hi MelodicEmu
I can see that a line test has been completed this morning and this test is clear - No faults detected.
Is the phone currently connected at the test socket?
