Home Phone
Landline Down
WysallRover
Message 20 of 20
Hi.
I received a text recently notifying me of planned work to swap out equipment at local exchanges on 2nd September and that my services would be disrupted for no more than 2 hours between 8:00am - 6:00pm.
Later on that day, I noticed my landline was disconnected. I was expecting it to happen. However, it did not reconnect by 6:00pm. I decided to leave it overnight in case work at the exchange was overrunning. I did though perform an online test on my connection that evening which initially indicated a potential problem.
The next morning I received a text saying that testing on my connection showed that "everything appears to be running smoothly within the network".
I then initiated a long live chat with Anas, who was very patient and helpful in trying to identify the problem and find a solution. Unfortunately, it seems the system shows no fault on my line, thereby indicating a fault at my end.
Having had problems long ago in the past, I performed all the usual required checks (before live chat, and during), connecting to the master socket etc., with no change. I do realise that all possibilities need to be covered, but the fact is that nothing has changed with my set up and I am just going through the same checks over and over. Equipment and settings are exactly the same as they were on the morning of the 2nd and remain that way, apart from the tests carried out since.
I find it difficult to accept that the fault lies with my set up, as the issue has only arisen on the day work was carried out at the exchange. It is too much of a coincidence. As the assumption is the fault lies with my set up, the only other option is to book an engineer visit (£75 but refundable if the fault is found to be outside the property).
I do have a working internet connection with an isolated incidence where email would time out after a few seconds and require logging back in. It only happened once on the day and there have been no problems with that since.
So, the fault I have is that I have no dial tone, so cannot call a number. Trying to call my landline does give a ringing tone but the phone does not ring here.
I have spent much of today checking and rechecking, to no avail.
I have also attempted to use the Grandstream HT801 provided (but not used for some time) to establish a connection for the landline. Unfortunately, the unit will not register, despite numerous resets. Information elsewhere here in the Community suggests that it is locked to TalkTalk, so cannot be accessed, either by IVR or the WEB UI to change any settings. Trying to use the IVR just brings the "device not registered" message and then an engaged tone. Likewise, trying to dial out.
Any suggestions you have or further investigations you can do will be gratefully received and go some way to easing my frustration with the situation.
Thanks in advance.
19 REPLIES 19
Message 1 of 20
Hi Garry,
I'm sorry to hear this. Could you try removing Caller Display in your My Account please, then wait at least 4hrs and then re-add it again to see if this then works?
WysallRover
Message 2 of 20
Hi Michelle,
Thanks for the info.
Have to report unfortunately that although the landline is now working, Caller Display is not. My telephone only displays "Incoming Call" whether or not the call is from a "Private Number". I have checked the settings in My Account and Caller Display is selected. I've done the usual checks here. Can you look into this for me, or do I have to start a new discussion?
Garry
Message 3 of 20
Morning Garry,
Thank you for the update. If the fault was located at the exchange then no time related charges will be applied.
WysallRover
Message 4 of 20
Hi Chris,
The engineer has been this afternoon and traced the fault back to the exchange. It was related to the work done. As I understand it, my line had been forwarded through the wrong port. He says this is quite a common occurrence. Anyway, the problem has been resolved and I have a working landline again.
I did ask about the fibre connection but he doesn't work on that side. It seems the copper cable disconnection is not going to happen anytime soon, so I'll deal with that later!
Thanks again for your help, it is much appreciated. Can you clarify the situation regarding the charge for the visit please? Will I be charged and then refunded, or will there be no charge?
Garry
Message 5 of 20
Thanks for the explanation. Yes the engineer may be able to give you some advice but they certainly won't do the installation
WysallRover
Message 6 of 20
Hello again Chris,
The issue arose because of the location of the fibre terminal. When the engineer came to do the installation after I moved in, Full Fibre could not be installed because the fibre connection comes into the property behind the washing machine in the kitchen, so there is no easy access. Rather than leave me with no service, he had the idea to check the copper wire connection back to a local cabinet, found it was live and made the connection. This was in early January 2023.
I had Full Fibre at my previous address and tried to arrange a simple change of address before I moved, but had to take out a new contract. I can't remember who I chatted to here at the time, but having described the problem and there being no immediate resolution I agreed to accept the installation as is with no change to the contract as it was the easiest way to proceed at the time and I believe the price was lower than for a standard connection anyway. We came to agreement that the contract would stand but the connection would be a standard one. So, the contract agreed on 6/12/22, has been for a Full Fibre service, but I have an ordinary wired connection.
As I said, to complete the fibre installation, either the entry point needs to be relocated (not easy because I am on the first floor), or wiring into the property has to be installed/modified.
I will ask the engineer tomorrow what the options are and let you know but I doubt the fibre installation can be done then and will need another visit.
Garry
Message 7 of 20
Hi Garry,
Sorry, I can't see the other posts, could you just give a brief description of what the issue was
Message 8 of 20
Hi Chris,
Thanks for arranging that. I've confirmed the booking from my end.
I'm afraid I have no link for those posts. The log in procedure was changed and when I tried to update, the system would not recognise my username, saying no spaces allowed. At that point I had to create a new profile (same name without a space) as I was effectively locked out of the original.
If there is a secure way to send you the pdf of the contract I will do that if it's any help.
I've just done a search for my original username (with the space) and it is in the system, showing how many posts I had made, and the likes I recieved. However, I can't find any way of reading the posts. Maybe you can find a way in to read them.
Garry
Message 9 of 20
Hi Garry,
I've booked the first available afternoon appointment - September 17 2024, PM - please let us know how you get on.
Apologies, I can't find the previous discussion, do you have a link?
WysallRover
Message 10 of 20
Hi Chris.
I can be available for an engineer visit afternoons between 13:00 and 18:00, with one exception being 2nd October. I agree to any possible charges arising from the visit.
Just an extra piece of information regarding the checks I have done here. I have now tried three different telephones connected to the master (test) socket with the same results.
Before we go ahead with the fibre installation could you check something for me please? As I have said, the original install couldn't be done because of issues with the location of the incoming fibre connection. At the time, here on the community pages, I had a discussion about how to proceed. As I understood it, I would be charged for a fibre installation, even without one. I agreed to this at the time as it seemed the easiest way to get things settled, and I have no problem with that. If that is the case, then completing the fibre installation would not technically be an upgrade.
Since then I have had to create a new profile and user name because changes to the log in procedure caused a problem, so if you need to check those posts you will find them at "Wysall Rover" (with a space!).
Thanks,
Garry
Update: Have checked my contract, sent by email on 6/12/2022. It is actually for a Full Fibre installation.
Message 11 of 20
Hi Garry,
If full fibre is available you can place an order to upgrade anytime. If you would like us to arrange an engineer visit to investigate the fault can you confirm:
WysallRover
Message 12 of 20
Hi Chris,
Ah yes, as I thought.
Well it seems I have no option but to arrange an engineer visit. With the impending disconnection of copper cable services, would this be an opportunity to install the fibre connection properly now, as well as investigating the fault? It would be handy if it could be done in one go.
Garry
Chris-TalkTalk
Message 13 of 20
Hi Garry
The grandstream is provided for FTTP circuits with VoIP enabled, as you are now on an FTTC circuit there is no VoIP service, that's why there is no telephone connection through the grandstream.
If there is no dial tone with your telephone connected to the test socket then we will need to book an engineer visit. If you'd like us to do this please let us know and well confirm some details with you
Message 14 of 20
Yes, the logical side of my brain did suggest that if one part of the connection is working, the other should too!
I have just tried the test socket (for the umpteenth time) and there is no change. No dial tone. Cannot dial out. Tried ringing my number. There is a ring tone but the phone does not ring here. I guess that as the ring tone is produced, the system will say the connection is working. My initial thought was that something just wasn't plugged back in, or a switch (physical or software) not set, at the exchange while the work was progressing, or is that too simple?!
As for the Grandstream adapter, would that be  preset to only work with a fibre connection or one particular line number? That might explain why the unit does not register, as my number changed when I moved. If it should just work by connecting to the router though, regardless of which type of main connection into the property, maybe I've been unlucky and the unit is faulty. Or could the the failure to register be associated with the lack of a dial tone?
Garry
Message 15 of 20
Thanks for the explanation. If the Internet connection is working then then the telephone service should be working too. Line tests are passing, not picking up any problems. Have you tried connecting the telephone to the test socket? Your guide to main phone sockets - TalkTalk Help & Support
Message 16 of 20
Hi Chris,
Just spent an hour trying to log in. Try to log in, see verification code message, switch tab to see email with code, go back to tab with log in page and it has reset. Or end up in a loop to the Link Your Account page. My account is already linked but there is no option to log in with the linked account log in details on that page. Maybe I'm just thick.
Anyway, in answer to your question. No, my landline is still not working.
I've been thinking about this and maybe a possible reason for this problem could be related to the connection set up I had when I moved into my current address. I should have a Full Fibre connection as at my previous address. When the engineer came to do the install here, he found the fibre connection enters the property through the wall behind the washing machine! Extending that connection into the property will require a lot of work. On the day, the engineer tested back to a local cabinet and found the wired connection to the property was still active, so used that for the installation. At that time, I had an exchange here on the community about my contract and agreed to continue with the installation as it is. If the work at the exchange involved disconnecting copper cable connections that might explain it. Indeed, if that is the case, an engineer's visit will be needed to install the necessary cabling to restore the landline service, which would then be VOIP. Just a theory, but doesn't explain why the internet connection is unaffected...
Garry
Message 17 of 20
Hi Garry,
Thanks for updating your profile. Is your landline still not working?
WysallRover
Message 18 of 20
Hi Debbie,
Account number added to profile and landline number updated.
Garry
Message 19 of 20
Hi WysallRover
Please can you add your TalkTalk account number to your Community Profile. I can then take a look at this for you.
