on 21-05-2023 02:34 AM
Hi how do I set up call divert to my mobile as I don't have a landline phone just now do I need to have a landline phone to set it up thanks
on 24-05-2023 11:47 AM
Network divert can only be done when a fault is reported.
23-05-2023 06:15 PM - edited 23-05-2023 06:16 PM
It would usually only be done when a fault was on the line and you had no other option for keeping in touch.
Find a friendly neighbour who can let you use the phone plugged in to your BT socket for the few minutes it takes to set this up.
on 23-05-2023 05:37 PM
Hi I was told it could be done from your end thanks
on 23-05-2023 02:14 PM
It has to be done from your side via the landline handset, is it possible to connect or even borrow a handset to connect the master socket and follow the instruction given
on 23-05-2023 01:45 PM
Hi I can't set up call divert from my landline as I don't want my ex partner to no about call divert it was meant to be done on Saturday I spoke to casey o. Chat can you sort this please
on 23-05-2023 01:08 PM
Call divert is added to your account instructions are in our help page About Call Divert - TalkTalk Help & Support
on 23-05-2023 12:41 PM - last edited on 23-05-2023 01:06 PM by Arne-TalkTalk
Account number is *** removed for security ***
on 23-05-2023 11:41 AM
@Jansnooka Can you add your account number to your community profile and I can look into this.
Thank you.
on 22-05-2023 06:43 PM
Hi my landlines was meant to be diverted to my mobile yesterday and it hasn't been sorted
on 22-05-2023 01:18 PM
Hi Jansnooka
Did you manage to sort this out?
let me know if you need any assistance.
Regards.
on 21-05-2023 08:53 AM
You set it up as a boost via My Account, @Jansnooka, and there is a monthly charge.
But to activate it, you need to press numbers from the landline phone etc.
It can be set up by Talktalk when there's a fault, so in theory it should be possible to ask them to do this for you, but you won't have direct access to controlling it without a landline handset yourself.
For example, even if you never want it switched off, you might have a change of mobile number that you needed to then set it up for. Might be simpler to buy a basic handset!
https://community.talktalk.co.uk/t5/Articles/About-Call-Divert/ta-p/2205322
Staff are not on here at weekends - they respond during the day Monday to Friday.
