Home Phone
Landline noisy, phone won't ring most times.
Sidious
Enlightened One
Message 72 of 72
Could it be arranged for Openreach to attend as my landline has become noisy and the phone refuses to ring most times when the line is called.
The line is very noisy. I have done the usual of plugging straight into the test port of the NTE5. I have even tried the phone in a neighbours house, works faultlessly there!
Forgot to add, the FTTC Internet seems to be unaffected. Prior to testing using the test port, the VDSL connection had remained for over a month.
I am obviously prepared to pay the fee if the fault lies downstream of Openreach's responsibility i.e. if the fault is on 'my side' of the connection.
Thank you,
Ant (AKA Sidious)
71 REPLIES 71
Message 61 of 72
There is a dialling tone, it dials out, but with a horrible scratchy and crackling sound.
When the line is rang from say a mobile, sometimes the phone rings but mostly doesn't. The person trying to ring in does hear the ringing tone. (Tried it myself)
Thanks again,
Ant.
Message 62 of 72
Please describe what you can hear when you try to use the phone?
- Silence
- Noise on the line
- Intermittent Dial Tone
- Consistent Engaged Tone
Message 63 of 72
No, just the phone. The broadband (FTTC) seems fine. Doesn't drop, buffer, or anything like that when viewing streaming services.
Thanks again,
Ant.
Message 64 of 72
Are you having issues with your internet/broadband? Is it landline only that has issues or broadband too?
Message 65 of 72
No, we don't have anything like that. Thanks.
Ant.
Message 66 of 72
Do you have any active monitoring for life threatening health reasons which is solely dependant upon your TalkTalk Broadband or Telephone line?
For example a care alarm, lifeline, health pendant or fall detector.
Message 67 of 72
Yes, I'm messaging this from my home. The landline is 01248 ****82, i.e the one attached to my account.
Message 68 of 72
Hi there @Sidious, I will look into this for you. Please confirm if you are messaging us from home.
Message 69 of 72
Hi Ant. it had to be said😁 The team will get things checked out for you after the weekend, enjoy the peace and quiet.
D
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
Message 70 of 72
Cheers. I knew it was a bit late on Friday, but had to put it down while I knew what to write.
I actually prefer the humans on this board than automated tests; they've been really good in the past with the, thankfully, few problems I have had in the past.
Ant.
Divsec
Message 71 of 72
Hi @Sidious I'm sure the team here will help and your post has been escalated but it is now quite "late" on Friday so you might not hear till Monday.
You could always run the line test in my account which, should a fault be detected will also set the wheels in motion.
