on 24-10-2024 03:19 PM
Hi, I'm getting MIssed Calls with No Number every 30 minutes on my landline, since a power cut last week. I'm using WiFi Hub 2 with the phone plugged into the router. Help would be appreciated!
on 25-10-2024 01:59 PM
Hi Debbie
Your fix seems to have worked, I've had no more missed calls since this morning.
Thanks for your fast response. Great service.
Rob
on 25-10-2024 01:43 PM
on 25-10-2024 10:40 AM
Hi @rob1950
Apologies, I've made the change again.
Please can you monitor the line and I will check in again with you later this afternoon.
on 25-10-2024 10:36 AM
Hi Michelle
No, I'm afraid nothing's changed. I'm still getting Missed Calls every 30 minutes, at the same times as before the update.
Anything else you can try?
Rob
on 25-10-2024 08:46 AM
Morning rob,
Is everything now working ok for you?
on 24-10-2024 03:26 PM
I've applied a small update to your router, this should stop the calls.
Test and let me know if they stop.
