Home Phone
Mystery phonecalls
Teegee333
Message 14 of 14
I just recently was upgraded to full fibre. My phone shows 40  calls that did`nt ring or anything overnight.Any ideas? Thanks.
13 REPLIES 13
Message 1 of 14
That's great, thanks for letting me know 🙂
Message 2 of 14
No Mystery calls at all last night (6th) Thanks.
Message 3 of 14
Thanks but we've just made a change so hopefully you won't receive any more
Message 4 of 14
Hi Chris,
                 still get 40+ mystery calls overnight.
Message 5 of 14
We've made some changes that should hopefully resolve the problem. Could you monitor and let us know if the issue is now resolved
Message 6 of 14
Hi Teegee333,
We'll look into this and get back to you.
Message 7 of 14
I do not have a digital voice adaptor.I plugged the phone straight into the router.Is that OK?.
Message 8 of 14
I am using the latest wi-fi hub router.Thanks.
Message 9 of 14
I'm sorry to hear this. Can I just confirm, are you currently using the wifi hub 2 router or the eero?
Message 10 of 14
Hi Chris,
                 Still recieving the calls.40 overnight last night, wednesday the first of november.
Message 11 of 14
Hi Teegee333,
Could you just let me know if you are still receiving the calls
Message 12 of 14
Thanks very much.
Gondola
Message 13 of 14
It's a handset design fault.
Certain handsets, commonly those made by BT like the 8500 and 8600, do have a design fault. The Digital Voice service sends an auto reset that will reset the service after a call has ended but not properly terminated. It's a standard function to ensure that all calls are ended properly. But on the affected handsets the receipt of the reset registers a call. Most handsets have no problems I should add.
TalkTalk do have a fix so I'll request that for you. You'll get a response here next week from TalkTalk Support.
