Home Phone
No calls in or out
Garymills
Message 4 of 4
I have got no dialling tone cannot dial out and cannot receive I am paying for call boost and I can’t use it
3 REPLIES 3
Message 1 of 4
Hi @Garymills
Openreach have closed the fault as resolved. Is everything working ok now?
Chris-TalkTalk
Message 2 of 4
Hi Gary,
Line test is failing so I've logged this out to Openreach for investigation. Openreach will investigate over the next 72 hours and may contact you directly if they need to access your home
Message 3 of 4
Hi @Garymills
Thanks for creating a new topic.
Please can you add your name and TalkTalk landline number to your Community Profile, I can then run some line tests and investigate this fault.
Anonymous User
