Home Phone
No dial tone for landline - broadband working fine??
GaryNR32
Message 8 of 8
I don't get a dial tone with my landline and yet my broadband is working fine.
I believe the phone is working OK but doesn't ring when I dial it either.
Any suggestions?
Also, do I have to have a landline if I never use it?
Gary
Gary
7 REPLIES 7
Message 1 of 8
I'm glad to hear that service has been restored for you.
Message 2 of 8
Well, well , well....
I have a dial tone and I can ring my landline again!!!
So there was a problem on the TALKTALK side and not my side, as I thought.
Thanks for getting it resolved but no thanks for the hoops your chat support staff made me go through....
Gary
Message 3 of 8
I can see that this fault is now logged out to Openreach.
Message 4 of 8
Yes, I've already run many speed tests and connection tests, with varying results.
Have spent a few hours chatting to support staff too but to no avail....
Just thought I'd try a different angle of attack.
Gary
Message 5 of 8
I see that you do in fact have a problem with your Broadband that you posted about today:
https://community.talktalk.co.uk/t5/Broadband/Broadband-speed-stability/td-p/2986192
This will be related to the phone line not working.
GaryNR32
Message 6 of 8
I don't have a second handset, so I'd have to go and buy one just for that purpose.
Thanks for your response, let's see what TalkTalk say.
Gary
Gliwmaeden2
Message 7 of 8
It's a good idea to check with a second handset regardless, but otherwise it sounds like there's a fault on the line, @GaryNR32.
Have you checked it in My Connection (via Service Status Dashboard)? Go via the forum menu: help with your service.
You can't have traditional ADSL or FTTC without the landline even if you never make calls - the infrastructure uses it.
With Full Fibre, new infrastructure is installed and you don't then have a landline.
