Home Phone
PHONE LINE WIRE LOOSE OUTSIDE MY PROPERTY.
nbjones57
Message 35 of 35
Hi. The tension in the overhead copper cable telephone wire outside my property has come loose and so it is sagging. I’m concerned since it crosses a busy road. How do I get it fixed?
Thank you
34 REPLIES 34
Message 21 of 35
Hi Debbie.
Sorry I forgot to get back to you after the bank holiday weekend. The cable outside has been reattached and is no longer loose - much safer.
Unfortunately, I still have a fault on the line. Incoming calls are still dropping the connection. This problem was obviously not related to the loose external wire. I’m not at home right now to do a connection test with you but if you could run a diagnostic test without me being there, then please go ahead.
Message 22 of 35
Hi Nick
Has the fault been resolved following the engineer visit?
Message 23 of 35
Hi Nick
How are you getting on following the engineer visit?
Message 24 of 35
Hi Nick
I have arranged the Openreach engineer visit for 27/04 AM (8am - 1pm)
Message 25 of 35
Hi Nick
Thank you. I'm just sending you a Private Message to confirm some details so we can arrange an Openreach engineer visit.
Message 26 of 35
Hello Debbie,
Borrowed a phone and retried the test as you described. Problem persists with incoming calls still being disconnected.
Message 27 of 35
Hi Nick
Alternatively, would you be able to test your phone on another line? (friend/family)
Message 28 of 35
I’m sorry Debbie, but I don’t have another phone handset to try this out.
Nick
Message 29 of 35
Hi Nick
If you are experiencing a fault with your service then I can raise the fault to Openreach for you.
Have you tested with a different phone at the test socket (with the router removed) just so we can rule out any potential equipment issues?
Message 30 of 35
Just tested the line…
outgoing calls seem fine, but incoming fails (phone rings once or twice then connection lost).
Since there is a disruption to service, should I *not* contact Openreach?
many thanks,
Nick
Message 31 of 35
HI nbjones57
Thank you. Can I just check, is your line/BB connection working ok? Do you have any noise on the line when making calls or any drops in connection?
If this is not service affecting then you can report this using the page below:
Report damage, vandalism or a health & safety issue | Openreach
Message 32 of 35
Hi Debbie.
Sorry. New to all this. Community profile updated as requested. 🙂
Message 33 of 35
Hi nbjones57
Please can you add your name and TalkTalk landline number to your Community Profile, we can then take a look at this for you.
Message 34 of 35
TalkTalk can only investigate service affecting issues on your behalf. This looks like like it needs Openreach intervention directly, see here:
https://www.openreach.com/help-and-support/damage-health-and-safety
